talk about Torque
Discussion in 'Fred's House of Pancakes' started by xsmatt81, Nov 12, 2008.
  1. xsmatt81
    xsmatt81 non-AARP Member
    522
    Vegas
  2. qbee42
    qbee42 My other car is a boat
    18,058
    3,073
    Northern Michigan
    Do you think we can get one of those into a Prius?
    Nice photos.
    Tom
  3. TonyPSchaefer
    14,816
    2,497
    66
    Far-North Chicagoland
    There is, of course, the rumor that the 2010 Prius will get a larger engine. Perhaps it will look like this:
  4. efusco
    efusco Moderator Emeritus
    19,891
    1,191
    Nixa, MO
    How about a supercharger and a Nox injector??
  5. Rokeby
    Rokeby Member
    3,033
    708
    75
    Ballamer, Merlin
    I guess that with the resulting forward weight bias that there'd be much
    less chance of the Traction Control kicking in at awkward moments. :rolleyes:
    Better thow in a strut tower brace to help control understeer. :D
  6. miscrms
    miscrms Plug Envious Member
    2,076
    523
    Phoenix, AZ
    I seriously doubt that thing can achieve T2B5 ;)
    Rob
  7. tripp
    tripp Which it's a 'ybrid, ain't it?
    4,717
    79
    Denver, CO
    Might need BT to make a new chassis stiffener too. Cor luv a duck, that's a HUUUUUUUGE engine.
  8. markderail
    markderail I do 45 mins @ 3200 PSI
    2,260
    163
    Pierrefonds (Montreal) Quebec Canada
    Torque converter. I learned something.
  9. tripp
    4,717
    79
    Denver, CO
    Well, you can see why cars are so inefficient. It's a cool contraption, but I wonder what the losses are via this thing from engine to transmission. And then there are loads of other such devices, no doubt, each one incurring some sort of efficiency penalty.
  10. Ichabod
    Ichabod Artist In Residence
    1,794
    Newton, MA
    In trying to visualize that torque converter working, I think you can see that when it's not "working," i.e. actually converting torque, it's not really losing much power because the whole thing, liquid and all, just spins as a unit. When it is converting, internal parts/fluid are spinning at different speeds.
    Isn't there still something like this in the Prius engine (aside from the PSD doing torque conversion electronically)?
  11. Danny Hamilton
    Danny Hamilton Active Member
    926
    94
    Greater Chicagoland Area
    Honestly, I don't know (so I should probably keep my yap shut and wait for someone who does know to answer).
    However, since I can't seem to keep myself from sharing my thoughts on the matter, I'd have to say that I can't think of why the Prius would have something like this. What purpose would it serve? Perhaps it does, but I'd be surprised.
  12. qbee42
    18,058
    3,073
    Northern Michigan
    There are losses. Spinning all that fluid isn't free. That's why high efficiency automatic transmissions lock out the torque converter at high speed.
    As for your question, no, the Prius does not have anything like a torque converter, nor would there be any reason to have one. No clutches, no shifter bands, no torque converter, no shifting gears. The only thing the Prius has is a fixed ratio planetary gear set and a torsional damper between the ICE and gears. The torsional damper absorbs shock when the engine starts. All of what would be done with gearing and a torque converter is done by the PSD by varying the ratio of power that goes directly through the mechanical path and that which goes through the electrical path.
    Tom
  13. tripp
    4,717
    79
    Denver, CO
    The biggest loss must be in converting the chemical energy in the petrol into mechanical energy in the pistons. Doesn't that one step account for something like 66% of the losses? I seem to remember reading somewhere that the theoretical max efficiency of an ICE is 33%. Is that close or am I full of shite?
