Talking about Compression Ratio
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by KevinPluggedIn, Mar 7, 2018.
Tags:
  1. KevinPluggedIn
    KevinPluggedIn Junior Member
    25
    33
    2014 Prius Plug-in
    Last week, a Co-Worker and I were talking about engine compression.
    He asked what it was for the PIP, and we were shocked to see, via a quick internet search, that the compression was 13:1, far higher than many "High Performance" vehicles on the road.
    My questions for the experts here are:
    - Is the 13:1 figure accurate?
    - If so, any idea why that was done, and how does the higher compression figure in to the performance equation for the PIP?
    - If 13:1 is accurate, why is Premium fuel not recommended?
    Thanks for your insight.
    pilotgrrl likes this.
  2. 4est
    4est Active Member
    207
    121
    Romania
    2013 Prius Plug-in
    Excel
    High performance engines usually are turbo, so less compression ratio
    pilotgrrl and KevinPluggedIn like this.
  3. gallde
    gallde Active Member
    238
    131
    Tarrytown, NY
    Remember that the Prius engines run on an Atkinson cycle, which requires computer-controlled valve and spark timing. That's how it can use regular fuel without preignition issues.
    Pluggo, pilotgrrl and KevinPluggedIn like this.
  4. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    It would be more accurate to say the expansion ratio is 13 to 1. We are used to Otto cycle engines where compression and expansion ratios are equal.
    The compression ratio is about 8 to 1 as the intake valves stay open for about 1/3 of the compression stroke, so Fuel/Air can escape back into the intake manifold.
    Pluggo, mczouav, 4est and 4 others like this.
  5. KevinPluggedIn
    25
    33
    2014 Prius Plug-in
    Very insightful. Thank you all. I learn something new every time I visit the board here.
    Raytheeagle likes this.
  6. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    In an Otto cycle engine, the exhaust gases are still expanding even after leaving the cylinder since the compression ratio and expansion ratio are the same and the mixture is much hotter.
    In an Atkinson cycle engine, with a compression ratio of 8 to 1 and an expansion ratio of 13 to 1, more expansion happens in the cylinder. So a big, loud exhaust is less about performance, and more about annoying the neighbors, as gas pressure at the end of the power stroke is almost atmospheric.
    fuzzy1 and pilotgrrl like this.
  7. Yea Right
    Yea Right Active Member
    232
    115
    Seattle
    2014 Prius Plug-in
    And .... As the efficiently of a motor increases, you can get away with higher compression ratios even with lower octane fuels. Both intake track and exhaust savaging play into it as well.
    KevinPluggedIn and pilotgrrl like this.
  8. fuzzy1
    10,723
    Back when my 2010 was released, Toyota's marketing materials even correctly listed this as "Expansion Ratio." But by the time I upgraded with a 2012, marketing had reverted to the less accurate but consumer-familiar "Compression Ratio".
    KevinPluggedIn likes this.
