tall users above 6’3
Discussion in 'Gen 5 Prius Main Forum' started by krzysiek1976, May 17, 2026.
  1. krzysiek1976
    krzysiek1976 New Member
    poland
    2024 Prius
    is there anyboady above 6’3 and can share experience if position is ok on long distance, visibility of road, cockpit is ok, enough place for head and legs? solar panels minimize place above head?
  2. Gokhan
    Gokhan Senior Member
    6,714
    2,672
    Paramount CA
    Height is overrated. LOL.
  3. Probity
    Probity Junior Member
    46
    36
    Covington LA
    2026 Prius
    Just about every Gen5 review/comment I've seen negatively mentions the gauge cluster placement. Combined with the low and sloping roofline, I think it applies whether you're 5'8" or 6'5". This excerpt from one review pretty well captured my impressions:
    The weird party trick is the instrument cluster placement. Instead of sitting directly behind the steering wheel like most cars, the Prius puts its digital gauge display up high near the base of the windshield. Toyota’s idea is “eyes up,” which I get in theory. In practice? Your experience depends heavily on how you sit.
    If you like a higher seat position or you tend to raise the steering wheel for comfort, there’s a decent chance you’ll partially block your own view of that cluster with the rim of the wheel. I’ve driven enough press cars to know this isn’t just me being picky it’s a common complaint among drivers who don’t naturally sit low with their arms extended.
    You can usually adjust around it lowering the seat slightly, bringing the wheel down or out but that’s where the learning curve comes in. Some people will find their sweet spot quickly. Others will be mildly annoyed every morning until they do.
    I'm 6'4". Got a '26 LE (base HEV) for my daughter, drove it 2000+ miles to her in California. Cluster placement definitely irritating but I could work around it. Also being old/tall/cranky, getting into/out of the Prius was challenging - ergonomics for old and tall folks not great. Having said that, actual driving comfort for me was fine.
    Edit: forgot to mention, yes I did remove the rear headrests for better visibility, it helped.
    #3 Probity, May 18, 2026
    PrimeDan and Winston Smith like this.
  4. schja01
    schja01 Senior Member
    1,868
    1,236
    Chicagoland
    2024 Prius
    Limited AWD-e
    I wonder why Toyota no longer offers a HUD in the Gen5. At least on the Non-Prime.
    Sloping windshield the reason?
  5. dicknose
    dicknose New Member
    Toronto
    2024 Prius Prime
    XSE Premium
    Could very well be due to the windshield angle. The instrument cluster is positioned like a HUD, much higher than in other vehicles.
    schja01 likes this.
  6. Winston Smith
    Winston Smith Active Member
    476
    344
    OH
    2024 Prius
    LE AWD-e
    Guilty. I'm only 6'2", but unless the seat is all the way down, I can't get into it.
    I don't have a beef with the instrument cluster location, and I'd have placed it higher and farther out, but it does limit where the wheel can be placed.
  7. Mendel Leisk
    42,354
    Wow. Is it a sunroof model? That tends to reduce headroom an inch or two.
    Guess I better not recommend one for our 6'-7" son...:confused:
    GcinFl and Probity like this.
  8. bisco
    52,862
    I wouldn't even recommend the new Camry
  9. Winston Smith
    476
    344
    OH
    2024 Prius
    LE AWD-e
    No.
  10. rjparker
    rjparker Tu Humilde Sirviente
    11,116
    6,975
    Texas Hill Country
    I am 6' 3" which works in a gen2 or a gen3 v but not in a gen5.
    The first time I got in turned out to be the last time. The Camry is all around better and less money.
    The size of gen5 reminds me of the glorious 2002-2005 two seater Thunderbird.
    It had a 3.9 L Jaguar V8 engine and a removable hardtop with port-hole windows.
    But it was made for 5' 10" people. I still see them occasionally and wish I could fit.
    #10 rjparker, May 18, 2026
  11. Winston Smith
    476
    344
    OH
    2024 Prius
    LE AWD-e
    I thought the Camry was even tougher. The wider door sill made the seat seem even lower.
    If you are on the tall side, not limber and have knee problems, neither is great.
    I tell myself that the in and out ordeal will keep me young.
  12. Gokhan
    6,714
    2,672
    Paramount CA
    No, because that strange Gen 5 pop-up meter gauge replaced the Gen 4 HUD as a quasi-HUD.
  13. mingc
    mingc Member
    104
    74
    Portland, OR
    2023 Prius
    XLE AWD-e
    And I'm 5' 10" and had to change how I get into the car so I don't bump my head against the top of the door opening. I now sit butt down first, legs outside the car, and then swing both legs in.
    Winston Smith and schja01 like this.
  14. schja01
    1,868
    1,236
    Chicagoland
    2024 Prius
    Limited AWD-e
  15. Gokhan
    6,714
    2,672
    Paramount CA
    Very happy with my 2021 Prius Prime Limited PHEV. Very roomy with a high roof. Best fuel economy of all Priuses (close to 70 mpg in the HEV mode) due to its unusually low ground clearance—better than the Gen 4 Eco and Gen 5 LE. Fully loaded. Best Toyota color ever (Blue Magnetism/Spirited Aqua Metallic). The only thing I wish it had was TSS 4.0 instead of TSS 2.0, but TSS 2.0 is OK.
  16. VelvetFoot
    VelvetFoot Senior Member
    1,408
    545
    New York State
    2026 Prius
    58 mpg On First Tank | Page 4 | PriusChat
    Gokhan likes this.
  17. Winston Smith
    476
    344
    OH
    2024 Prius
    LE AWD-e
    I still get in with one leg, but I was having a bad time with my left knee when getting out. An old man shared the swinging both legs out trick with me.
    mingc likes this.
  18. Preebee
    Preebee Senior Member
    897
    782
    Midwest
    2026 Prius Plug-in
    SE
    Absolutely, positively, nobody cares that you are happy with your G4 in the G5 forum. I cannot believe you are still in here trolling.
    And no, the "Turquoise Jewel" does NOT exceed the MPG capability of the G5 LE. I've gotten over 700 miles on a tank and there was still plenty left to go further.
    Cannot believe people are still complaining about the instrument cluster... :ROFLMAO:
    I'm 6'4 in shoes and the only place where I have to be careful is getting in/out. But that's likely the case for just about any height. The low roof and the good looks come as a package deal.
    I've read about 6'7 guys being totally comfortable behind the wheel. It's all about the angle of the seat back.
    GcinFl and VelvetFoot like this.
  19. Winston Smith
    476
    344
    OH
    2024 Prius
    LE AWD-e
    That was likely a young and limber driver.
    It works for me, but it's easy to understand why it might not work for others. The ordinary process for wheel adjustment is to put the wheel where it is comfortable, and the entire cluster is still visible.
    The conventional cluster location is a consequence of the position of the windscreen so close to the top of the steering wheel that any driver could easily touch it while belted in. Look at an old MG or Porsche and you'll see a dash barely deep enough for a pack of cigarettes the long way.
    The Prius cluster is a half measure. It's farther away, which is neat for older eyes, but it's still only half way to the windscreen. I wouldn't have minded having the display pushed all the way back to the glass. Make it a little height adjustible and it should work for anyone.
  20. notspam3
    notspam3 Member
    139
    76
    Toronto
    2024 Prius Prime
    XSE Premium
    Gen5 is tight for getting in and out of @6'1". The A pillar is a big blind spot.
    Go to a dealer and take a test drive and make your own opinions.
