Taller tires?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by bobzchemist, Mar 15, 2018.
  1. bobzchemist
    bobzchemist Active Member
    507
    342
    Kennesaw, Georgia, USA
    It may be time to change tires - and I'm hoping to get a bit more ground clearance when I do. Does anyone know if 205/65/15's or 195/70/15's will fit without rubbing/reducing turn radius? Information on here seems inconclusive when I searched.
  2. Prodigyplace
    12,720
    11,852
    Central Virginia
    @sfv41901 and others in California are probably the largest group that have tried other tires & rims.
    He runs Hybrid Pit which services Prius and sells aftermarket & JDM parts & accessories.
    Szulkarn and sfv41901 like this.
  3. bobzchemist
    507
    342
    Well, my driving to Cali from Atlanta just to go to Hybrid Pit isn't likely, so Sean, do you have any long-distance advice you could give me?
    Burna J, sfv41901 and Prodigyplace like this.
  4. Prodigyplace
    12,720
    11,852
    Central Virginia
    I hoped he would. That is why I tagged him in my previous post, Perhaps Masta Sean can take a road trip... :D
    sfv41901 likes this.
  5. JayLn
    JayLn Active Member
    248
    141
    Four Touring
    It will not rub even 215 will not rub, but carefully you will reduce your mpg if you go wider, get narrower tires if you want to increase your car mpg, if I were you get 175, 215 or 205 won't do anything good with regards to gas and if you don't corner like a race car driver this will not do much either because it is tall. One guy I know who do uber full time is using 175 65 17 and he said he gets 4-5miles more per gallon, I asked how about grip, he said he don't notice the difference because he said he drives normal not like rushing so he can get 5star everytime.
    RMB and Prodigyplace like this.
  6. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    U should be fine.
    Road trip........where we going?
    iPhone ?
