Tanabe Strut Tower Brace and the Recall
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Jay J, May 29, 2014.
  1. Jay J
    Jay J Active Member
    469
    253
    Torrance, CA
    Just a heads up to everyone here with the brace...
    Take it off, as well as the LH bracket, before you go in for the recall; otherwise it cannot be performed.
    Thanks
    -Jay
  2. mrstop
    mrstop PWR Mode
    742
    329
    109
    Cincinnati, OH
    Thanks for the heads up. Did they say why? Was the fuse box access the issue? I have the Cusco brace which doesn't interfere with the fuse box so I'm curious if the same applies?
  3. PriusInParadise
    180
    91
    Hawaii
    A 3-in-1 fuse (50A-30A-30A) needs to be removed during programming to prevent other control modules from talking on the data bus and potentially corrupting the flash.
  4. mrstop
    mrstop PWR Mode
    742
    329
    109
    Cincinnati, OH
    Thanks. So it sounds like as long as they have fuse box access you should be okay.
  5. nedear88
    nedear88 My 1st Prius.
    246
    142
    San Bruno, California
    I had mine done "without" taking the brace off!. I DID ask the service advisor before I sign the work order. They did the update without issue take off the fuse box cover, I had the Blackbox camera mounting in window and records every seconds during the update process.
