Tank Empty - Only 320 miles driven
Discussion in 'Gen 2 Prius Fuel Economy' started by ingyaningya, Mar 8, 2016.
  1. ingyaningya
    ingyaningya Junior Member
    70
    17
    Miami
    No, I just take off now as soon as I press POWER. I am also not trying to stay in EV mode for extended periods of time
    52,862
    the gen 2 has a rubber bladder in the gas tank, so you can never fill it accurately. best to average your mpg's over time. the more tanks, the more accurate the average.
    #22 bisco, Mar 8, 2016
  3. fuzzy1
    10,710
    One bar, not yet blinking, so you were not quite down to the last warning. Beware that at this point, some Gen2 Prii with funky or partially collapsed bladders are getting close to fuel starvation. But many others still have plenty of fuel range remaining. You won't know which you have until you actually run dry. :-(.
    335 miles / 8.5 gallons = 39.4 MPG. But your MPG display said 49, suggesting that you burned only 6.8 gallons since purchase. Based on past discussions, I will guesstimate or swag that you burned roughly 7 gallons (the MPG display is not perfect, but less over-optimistic than 2010+ models), and the remainder of the difference was because the tank was not quite full at delivery, despite showing 10 bars.
    But it will take at least one more refill, maybe several more, to really pin this down.
    PS check your tire size, to make sure any replacements are the same or similar size as the OEM tires. A different size will throw off the MPG display.
  4. ingyaningya
    70
    17
    Miami
    Update: I filled up my tank 3 days ago, and now the first bar has disappeared on the fuel gauge after 93 miles driven
  5. bisco
    52,862
    yes, that is quite common. you can move along, these aren't the droids you're looking for.
  6. Lucifer
    Lucifer Senior Member
    1,014
    486
    Nh
    You want to check the amount of oil in the ice, it should be 2/3rd's up to the full mark, to much and the maaf sensor get's gunked, but the sweet spot is 2/3rd's, cycle the emergency brake on and off and go 38-40 on the air, clean the cabin air filter, and trickle charge the 12v at 2 amps once every two months.
  7. ingyaningya
    70
    17
    Miami
    I don't quite understand what you mean by "go 38-40 on the air" and "trickle charging"
  8. Lucifer
    1,014
    486
    Nh
    40 front 38 rear
    Charging your 12 volt battery, slowly with a 2 amps trickle charger
  9. ingyaningya
    70
    17
    Miami
    What I really don't understand is how people have told stories on how they get 400 or even 500 miles off a tank of gas in their Prii and I'm lucky to get over 300.
    After filling up the tank my self, it appears to be consuming fuel at the same rate that it was before. It went down another bar last night after driving 32 miles.
  10. jdenenberg
    jdenenberg EE Professor
    3,961
    1,957
    Trumbull, CT
    2020 Prius
    LE AWD-e
    That is because the gas tank is rated to hold 11.9 gallons of gas and a Gen2 Prius gets an average of 46 MPG (multiply it out). Some "hypermilers" have actually gotten 700-800 miles on a full tank.
    The issue with the tank is that the "bladder" (not used outside the US or in Gen3 or later Prii) can get stiff and then the back pressure during a fill-up causes the pump to shut off prematurely.
    JeffD
  11. ingyaningya
    70
    17
    Miami
    I realize that the Prius gets about 46 mpg, and in that sense I should be getting 400 miles on a tank at least, but I'm not getting even that.
  12. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    They are just that. Stories. Actual range will vary.The rest of us will be average and get 45 mpg with about 350 a tank.
    lar.smith42 likes this.
  13. fuzzy1
    10,710
    Some Gen2s have well behaved bladders that allow longer distances, some have very finicky little bladders that can't go nearly as far. Sort of like many humans. :)
    Gen3 owners can consistently go farther, both from higher MPG and from lack of bladder issues. And some have learned that they can go far beyond the very last low fuel warning without actually running dry. But numerous (not all) Gen2 owners have run into a nasty surprise when attempting the same.
    mmmodem likes this.
  14. bisco
    52,862
    bladders. bad for cars and humans.
  15. ingyaningya
    70
    17
    Miami
    Is there anyway to get the bladder fixed to make it act better, or to get it replaced with a normal fuel tank all together?
  16. dolj
    dolj Senior Member
    8,646
    4,398
    Wellington, New Zealand
    Apart from the various tricks like taking the fuel cap off and letting it "breathe" for a couple of minutes, pumping slowly, holding the nozzle a certain way, holding your head to the left (or to the right), etc, no.
    I believe the only way to replace the bladder is to fully replace the tank in its entirety. I'm not aware of hearing that anyone has successfully done this. I don't believe North American Market Gen II Prius can have a bladder-less tank fitted.
    Sorry that there is not better news, but I do feel your pain.
    If you get 42-49 MPG (US) without doing anything special then you are doing ok. If you want to get higher MPG than that, you need to learn some basic hypermiling techniques. The two best "bang for your buck" techniques are Driving without Brakes and Pulse & Glide (link in my sig). As well as these, don't accelerate slowly or try to drive in electric mode only.
    #36 dolj, Mar 12, 2016
  17. usnavystgc
    3,159
    990
    Tucson, AZ
    How do you know you're only gonna get 320 miles on this tank? Lets see what happens before we make that assumption.
  18. bisco
    52,862
    sounds like you need a new bladder. $$$$$ did you already have the gauge reset?
  19. fuzzy1
    10,710
    Before he tries to 'see what happens', he should be sure to select a convenient time and safe location with low traffic, and consider taking along a spare can of fuel.
  20. ingyaningya
    70
    17
    Miami
    If by reset you mean re-calibrate, then yes I did
