Tank Empty - Only 320 miles driven
Discussion in 'Gen 2 Prius Fuel Economy' started by ingyaningya, Mar 8, 2016.
  1. bisco
    52,784
    how many tankfuls have you gone through since starting the thread?
  2. ingyaningya
    ingyaningya Junior Member
    70
    17
    Miami
    Okay, update: I filled up my tank on Wednesday, I had driven exactly 417 miles before the fuel gauge began to flash.
    usnavystgc and mmmodem like this.
  3. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    Good. Nothing is wrong then.
  4. usnavystgc
    3,159
    990
    Tucson, AZ
    Sounds normal!!!
  5. bisco
    52,784
    excellent!(y) how were your mpg's?
  6. ingyaningya
    70
    17
    Miami
    According to the computer, I averaged around 48 - 49 mpg
  7. bisco
    52,784
    nothing wrong with that!
  8. usnavystgc
    3,159
    990
    Tucson, AZ
    Another mystery solved by the Scooby gang!!
  9. ingyaningya
    70
    17
    Miami
    I hate to keep bringing up an old issue, but it still baffles me. I have a friend who owns a 2008 Prius who was so shocked when I told him that I only get around 400 miles on a full tank, as he says that he can milk 500 out of his, and he doesn't even employ any special driving habits. It's always warm where I live, so I know the bladder isn't contracting.
    Am I just overthinking this?
  10. bisco
    52,784
    you're discounting the bladder issue. the tank holds 12 gallons when the bladder is working properly. 48 mpg x 10 gets you to 480, so either the bladder isn't allowing you to fill all the way, or the low gas light is coming on prematurely.
  11. ingyaningya
    70
    17
    Miami
    If the light is coming on prematurely, is there any remedy other than just living with it? Same with the bladder?
  12. bisco
    52,784
    there's a recalibration, for the fuel gauge in a thread here, if you can find it, or someone might link it.
  13. ingyaningya
    70
    17
    Miami
    I've already recalibrated it two times since I've owned the car. The fuel tank doesn't have to be full for the recalibration, does it?
  14. bisco
    52,784
    no idea. how many gallons can you put in when the low fuel light comes on?
  15. ingyaningya
    70
    17
    Miami
    It took 9 gallons
  16. bisco
    52,784
    that's not far off. 414/9 = 46 mpg. maybe your buddy is getting better mpg. how many gallons does he put in when the light flashes.
  17. ingyaningya
    70
    17
    Miami
    I have no idea how much he fills up. And I don't understand why he'd have higher mpg, as I employ multiple special driving habits including "pulse and glide".
  18. bisco
    52,784
    it could be his car vs yours. you really need to find out what his displayed and actual mpg's are.
  19. ingyaningya
    70
    17
    Miami
    After weeks of driving, I'm seeing a pattern. I'm consistantly getting 400 miles right when the low fuel alert happens, and the car never ever takes more than 8.5 gallons at refill.
  20. dolj
    dolj Senior Member
    8,633
    4,387
    Wellington, New Zealand
    So, approx 47 MPG (5 l/100 km) which could be better, but not too bad compared to an F150.
