Tappet clearance
Discussion in 'Gen 3 Prius Technical Discussion' started by Lemon Drizzle, May 27, 2022.
  1. Lemon Drizzle
    Lemon Drizzle Junior Member
    Hall Green, West Midlands
    Dearest Prius Community,
    Does anyone know the clearance values to adjust tappets on the 1.8 petrol prius engine? Inlet and exhaust please.
    Many thanks
  2. PriusCamper
    PriusCamper Senior Member
    13,467
    5,434
    Pacific Northwest, USA
  3. Lemon Drizzle
    Brilliant, thank you. But can this;
    1) hydraulic system fail?
    2) What can be the symptoms of a failure?
    3) Prognosis - how would I fix a failure in function of the system?
  4. BiaoH
    BiaoH Junior Member
    46
    Haverford, PA
    The hydraulic system is so simple that it does not fail very often as long as you change engine oil regularly.
  5. Mendel Leisk
    42,352
    They’re auto adjusting hydraulic, effectively zero clearance; no adjustment is needed.
  6. Lemon Drizzle
    That's good to know. Thanking you for your replies.
  7. ChapmanF
    19,027
    There are 16 individual lash adjusters, one for each valve, they're all identical, and they are fed from an oil gallery carrying pressurized engine oil from the oil pump.
    If you happen to have the camshafts out, you can lift the lash adjusters out of the head and test each one. There is a test method described in the repair manual. If one doesn't test well, you replace it. Each one is $33.59 suggested list.
    Toyota Service Information and Where To Find It | PriusChat
    PriusCamper likes this.
  8. Lemon Drizzle
    Many thanks. This is brilliant information.
