Tapping into Reverse light for backup camera. Help please
Discussion in 'Gen 3 Prius Audio and Electronics' started by dhman2006, Feb 2, 2018.
  1. dhman2006
    dhman2006 Member
    162
    27
    Boston, MA
    After doing much research I decided to buy a Autovox M1W backup camera system for my Prius, but I'm having some issue powering up the camera. I've had no problem installing the camera to the back of the car and running the wires into the hatch, but when I hooked up the camera to the reverse light I'm not getting any power to the system. I'm not sure what I'm doing wrong, but I'm hoping someone can direct me to the right direction.
    I've attached a picture of the reverse light wiring that I spliced to draw power to the camera. The red wire from the camera ties to the red wire shown in the picture and black (ground wire) got hooked up to the black and white wire shown in the picture.
  2. mygel
    mygel Junior Member
    46
    24
    Slovakia
    Check reverse light wires with multimeter, while someone put the reverse gear with brake pedal depressed. If u got 12V there (red for+, b/w for ground), then it should be ok. No idea further.. Did you attach wires properly (soldering)?, check circuit.
  3. Toyman321
    Toyman321 Junior Member
    Ventura County, CA
    Are you soldering or using a tap? Sometimes the taps don't make good connections.
