Tarnished fuse blades
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by ChapmanF, Sep 2, 2021.
  1. ChapmanF
    17,326
    On a short drive this afternoon, in dry weather fortunately, I sprayed the washers to get some dust off the windshield and then noticed I had no front wipers. Like, nothing. Not slow or sluggish or weak or sticking. Like unplugged.
    So I got home and glanced in the wiring diagram and pulled out the 30A WIP fuse (in the block under the instrument panel) and put in a spare, and then the wipers worked fine.
    The fuse that came out wasn't blown, but the blades showed tarnish. So I shined them up with an art eraser and put the old fuse back, and now the wipers are fine again.
    I suppose my 2010 might be reaching the age where I ought to have an art eraser in the glove box.
    JohnPrius3005 likes this.
  2. xliderider
    xliderider Senior Member
    8,055
    3,222
    Honolulu, HI
    I've noticed similar tarnishing on the fuse tap I use to power a relay for our foglight/DRLs.
  3. Rebound
    Rebound Senior Member
    3,972
    2,626
    Portland, OR
    This is very good to know, in case some electrical gremlins come my way.
  4. ChapmanF
    17,326
    My in-car spare fuse and light bulb box now also has a Pentel Hi-Polymer white cap-style eraser in it. (I haven't tried that particular style yet, but it was what they had the first place I stopped, and probably will work ok. I got tired of standard-issue pink ones that always leave crumbs.)
