TB Hot water bypass
Discussion in 'Gen 2 Prius Accessories & Modifications' started by edthefox5, Jan 23, 2008.
  1. JerryCS
    JerryCS Prius camper with trailer hitch
    77
    Elk Rapids, MI
    Ed, sounds simple enough to bypass the throttle body in spring and reconnect in fall if you live somewhere like... Wisconsin.
    Jerry
  2. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    Like I said, my negative response is based on actually having done this mods on numerous cars and not seeing any benefit whatsoever. Your SOT (seat of the pants) guage are typically pretty well useless in an instance such as this.
    I'm not saying you shouldn't post the info for it may make a difference on these cars and in certain climates but since my experiences have been different I will post the "negative" response to the idea to keep things in perspective. :)
  3. bruceha_2000
    bruceha_2000 Senior Member
    3,054
    302
    Northwest VT
    2018 Prius Prime
    As you know, it can get pretty toasty up here in the summer. Not like Florida, Nevada, etc toasty (toasted??) but 80's and 90's are quite common.
    That is why I figured a thermostat based automatic system would be best. It wouldn't bypass in the winter and you wouldn't have to remember to disconnect/reconnect seasonally :) Plus, it would provide the most efficiency if the computers can be programmed to figure out exactly what the prime temp is to bypass.
  4. edthefox5
    edthefox5 Senior Member
    10,096
    4,835
    Clearwater, Florida
    Got my Scan Gauge today..hooked it up and it works perfect right out of the box. Concerning my TB mod the temps I saw were pretty much what I expected. During a highway 20 mile commute today with outside temps at 60F the block water temp hovered around 185-190 with the intake temp at exactly outside ambient temp around 60 f. Thats a 120 degree difference.
    The intake was cold to the touch when I arrived. The intake temp spiked a few degree's when I hit stop & go but the minute you rolled it archieved outside ambient. I do not expect any performance increase now but I assure you during the summer the car really enjoys it no matter if this performance cannot be seen on a standard dyno test. During the summer when outside air is 90+ and the block water temp is 200 I expect to see at least a 120 degree cooling difference between block & intake. In a car that has a CAI & performance muffler the difference is dramatic no matter what anyone says here. Maybe your testing a stock car? My last mild performance car had a CAI & headers and power tuned timing. It had a tiny bog when I punched it. After this mod no more bog. A dyno cannot replicate outside 70 mph wind cooling the intake and a dyno cannot replicate real life drivability improvements.All a dyno measures is max horse & torque numbers. Thats not always the whole story.
    P.S. Sorry about the pics..I took them while rolling.
  5. ken1784
    ken1784 SuperMID designer
    2,943
    1,384
    67
    Yokohama, JAPAN
    OK!
    Your intake temp was same as the outside temp.
    Your water temp was around 185-190.
    Then, please let us know your intake temp without your mod.
    We can't agree "Thats a 120 degree difference" unless we hear your intake temp without your mod.
    Also, how much power or mileage number did you get from your mod?
    [FONT=Arial, Helvetica, sans-serif]We would like to see a dynamometer[/FONT] test numbers.
    Does anybody agree?
    Ken@Japan
  6. edthefox5
    10,096
    4,835
    Clearwater, Florida
    Rolling not sure as I did not have a Scan before I did the bypass. I did once measure it with my laser thermo and I thought it said 116.
  7. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    Actually I've done the mod on stock LS1 equipped F-bodies and 5.3L trucks to a heads/cam/nitrous'd LS1 (11.12@123 ) in the 1/4mile) and a 5.3L turbocharged truck (550rwhp then 717rwhp). My buddy's dyno (DynaPack) can replicate real world driving conditions fairly closely and under any load he chooses to put on the car and at any RPM and throttle position (IE not just max HP/TQ at full throttle. Most dynos use a large fan to simulate wind flow through the engine bay. The point is, I'm deifnately not a noob when it comes to making HP. I've been drag racing Mustangs and LSx-based engines since the early 90s. :)
    [​IMG]My first race engine used this mod back in 1996. I could never tell a difference but it kept me from leaking coolant everytime I removed the TB so I kept the mod. Notice the two tubes on either side of the TB have no coolant lines on them? ;)
    All I'm asking is for you to provide the members of Priuschat some kind of quantifiable evidence to back up your claim before they risk a fuel milage decrease or altering emissions.
  8. BT Tech
    BT Tech New Member
    885
    South Florida
    I have done this mod on a number of LSx based corvettes including my own and it is worthwhile and costs next to nothing to do.
    As the OP has pointed out correctly, the purpose of running the heated coolant through the TB was to decrease any chances of the throttle sticking during severe cold weather which btw is NEVER a chance here in South Florida!! :)
    Anytime that you can lower your intake ambient temps (IAT) this is a good thing as it will most often result in slightly higher hp/tq and reduced chance of detonation occurring.
    IMO this is a great mod for near little cost and effort....
    Great post Edthefox5!!
  9. Pinan
    Pinan Member
    173
    Murrieta, CA
    FWIW. I checked today (mod not done) and when the WT was at 184°, the IAT was 80°. This at an outdoor temp of about 70°.
    Upper grill blocked. Measured with SG2.
  10. edthefox5
    10,096
    4,835
    Clearwater, Florida
    I don't care how many hot rods you own you still don't know what your talking about!:mad: Woo Hoo!!! Just kidding! You sir are a serious horsepower dude. I no longer feel qualified talking hop ups with you! I kinda agree with you. There has not been much if any performance improvement other than what I think I'm feeling in various portions of the power range. The car
    doesn't not like it though. I'm still hoping for some improvement in the hot deathbed of Florida summer but I gotta tell you that my big problem here is the Prius is a very bad test bed to get any performance improvement from.
    Case in point: Based on what the other poster said about re-directing the intake tube I took that step further and on a lark disconnected the intake tube from the noise deadening box. So it had the nozzle of the air cleaner box open. All filters intact though. The car did not like it. It ran ok but when you stepped on it it bogged and stumbled a little and man oh man was it loud. For a 1.5 it made quite a loud 4 barrel cracked open sound. Not in a good way.So the other poster was right too. That little motor is sucking some air volume when you open it up.So my conclusions are that it will be hard to do a simple small horsepower improvement to this car. Its maf /fuel map is very strict. Any intake improvement would have to be accompanied by a new fuel map software chip. Which would be hard to write given all its weird parameters and the fuel economy would be a throw away.Other cars I have owned responded so much better than this car to a bypass. There's some performance in this little motor I bet but at great expense to fuel economy I'm sure. So thanks alot for educating me. I'm going to leave my bypass on as its not hurting anything and bottom line it can't be good to have 200 degree coolant flowing through the TB during 100 degree summer heat.
    Sezy likes this.
  11. edthefox5
    10,096
    4,835
    Clearwater, Florida
    Thanks alot Brian. Just wish I had better performance from it. Other cars I have owned down here responded so much better to this easy mod.
  12. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    Edthefox5,
    I tried a couple tricks with the airbox like you did and could not produce and quantifiable results either. I was at the track and tried removing the airbox lid, then just the airfilter, then the tubing etc. and nothing seemed to make much of a difference in ET or MPH. The only big effect on my ET/,PH was how hot the inverter may have been getting with back to back runs in 100deg temps. My times were all over the place! Haha
    If you end up collecting more data please post it up. :)
  13. ken1784
    2,943
    1,384
    67
    Yokohama, JAPAN
    This is an interesting attempt.
    Following guy is trying to do the other way around, trying to heat intake manifold for increasing efficiency.
    Yahoo! Groups
    However, he also doesn't show us the numeric results.
    Ken@Japan
  14. statultra
    statultra uber-Senior Member
    798
    31
    Edison,NJ
    2001 Prius
    f8l when the inverter temp goes up like reallly up it makes the pull more.
    my inverter water pump burnt out, and i was running around with a overheating inverter ( no warning lights until it hit like 122 F ) but the power was amazing
  15. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    Interesting. I was told it may of been the cause for my times going downhill so bad. Next thing ya know people will be installing nitrous bottle warmers on their inverters for mo powa! haha
  16. SparrowHawk60
    SparrowHawk60 Happy to be green!
    411
    Town of Newburgh, NY, U.S.of A.
    Are you kidding me? Cars back in '60's had warm air directed to the carburetor to prevent icing. -The air cooled VW's had it since '50's.- Not only for the carb but for the intake manifold as well.
    Yes, the colder the ambient temperature the more susceptible the throttle body would be to icing. But this is a closed system due to the ducting to the air cleaner. The air is warmed (maybe not heated) while passing through this duct work due to the engines heat. Some of this ducting may contain vent hose's directly from the engine, adding even more warmth.
    In short if you want cooler air, open up the air cleaner system, remove any sound baffles, diverters, until air goes directly into the filter.
    Most air filters are very restrictive, and get more so as they get dirty. Aftermarket cone type filters work much better, and better still with 'piping' directly to the throttle body.
    Forget by-passing the cooling! It's there for a very good reason. Any cooling, any at all retards heat transfer to the "butterfly", I wouldn't worry so much about it freezing as I would it seizing!
  17. supernoob
    supernoob New Member
    Good idea. Such a valve is found on the Lotus Elise.
  18. statultra
    798
    31
    Edison,NJ
    2001 Prius
    sorry to bump, but this modification proves to be very important especially since i moved to south florida, since summer hit us here im seeing my IAT reach 120-130 degrees almost 150 sometimes, im going to attempt this modification tommorow and record results here
  19. SFO
    SFO Senior Member
    5,302
    4,250
    Northern California
    Since this mod made an appearance in another thread, how about a bump for some pictures?
  20. Kenny94945
    Kenny94945 Active Member
    860
    436
    Sausalito
    2016 Prius v wagon
    This is a "free" no cost mod.
    So why not if one doesn't not live in a cold weather area.
    Yes, cooling fuel is a worth while.
    Yes, cooler fuel may reduce detonation.
    Yes, detonation alters "timing"
    Yes, further a bottom breather or cold air intake in conjunction with the TB bypass would be an ultimate set up, yet not as much a "free" mod.
    No, horsepower increase...on a 100 hp engine, would never be noticed.
    True, no 1/4 mile elapsed time or speed.
    Unfortunately, no empirical MPG increase.
    Again as a hobby why not do a TB bypass?
    Even use colored hose clamps for the "wow" factor.
    So that's my two cent comment.
