Teardown issue
Discussion in 'Gen 2 Prius Main Forum' started by Mebeksis, Aug 5, 2018.
  1. Mebeksis
    Mebeksis Junior Member
    53
    17
    Covington, GA
    Doing the teardown to fix the combo meter and run into an issue. In the video I have, the air bag harness clips into the back of the glove box, but in mine, it clips into a solid metal cylinder (see pic). How can I get it out without breaking the clip? received_1837933926289163.jpeg
  2. Mendel Leisk
    42,368
    If there's no way to get at the backside of the clip (and I guess there isn't), use a clip removal tool like this is the most gentle:
    And if it breaks a bit in the process, maybe still fine, will still stay put?
    PriusCamper and ITBland like this.
  3. Mebeksis
    53
    17
    Covington, GA
    Got it. Found a tiny set of needle nose and was able to get the clip out without breaking.
    bisco and ITBland like this.
  4. PriusCamper
    PriusCamper Senior Member
    13,472
    5,439
    Pacific Northwest, USA
    Yep... if you take apart cars often, broken clips happen. Only difference between a pro mechanic and a DIY at home mechanic is that the pro mechanic has a box of replacement clips on hand and the DIY mechanic has to make yet another trip to the hardware store. :)
    fotomoto and jerrymildred like this.
  5. DMC-5180
    DMC-5180 Active Member
    294
    134
    The metal tube is part up the sub-frame, was it necessary too un clip it?
    Did the wire stay with the dash cover once it was removed?
    iPhone X ?
