Technician had to break oil filter cap then charged me for a new one
Discussion in 'Newbie Forum' started by Neets, Sep 19, 2021.
  1. ChapmanF
    18,214
    In fairness, what worry or issue could crop up for an oil filter cap inside of 3k miles?
  2. xliderider
    xliderider Senior Member
    8,140
    3,276
    Honolulu, HI
    I also put on an aluminum oil filter holder purchased on ebay, on both our Prius and Corolla.
    The added benefit over the plastic one is that the metal one stops turning after a certain point and cannot be overtightened like the plastic one.
    When I replaced the plastic cap on the Prius, I couldn't remove it because it was overtightened. Even with a breaker bar and a pipe over that to extend it, I could not break it loose. I ended up using a corded 1/2 inch impact wrench to bust it free. That impact gun was really wailing on it, I thought I was going to shear or damage the bolts holding the oil filter mounting plate to the engine block before that plastic piece would come loose.
    I highly recommend the aluminum filter housing replacement.
  3. Mendel Leisk
    41,463
    Or spin-on conversion, fix Toyota’s boondoggle. That’s how they voted, commencing sometime through model year 2017. Through Amayama, all the parts were around $65-70 CDN for me, plus $35 shipping.
  4. xliderider
    8,140
    3,276
    Honolulu, HI
    #24 xliderider, Sep 22, 2021
  5. Neets
    Neets Junior Member
    Port Angeles, WA
    Okay. I went in today and spoke with the service manager. No argument - he agreed with me and is refunding cap plus tax! So glad I ran it by this group and took initiative to challenge the charge. Thanks everyone.
  6. dig4dirt
    dig4dirt MoonGlow
    1,151
    741
    Lancaster Co PA
    2014 Prius c
    Sweeeet!
    Done deal, now decision is hard. Stick w them or still find another. Def a toughy.
    Neets likes this.
  7. ETC(SS)
    7,164
    Not everybody can change their own oil.
    HOWEVER (comma!!) everybody DOES make mistakes.
    If I remember the OP, you've been taking the G3 there for a while now, and this business did "make it right" when they made their mistake.
    I'd call it good, personally.
    @Neets
    Your car is over a decade old now, and there are some things out there that are a lot more scary than a $60 oil filter cap.
    Make sure that you're keeping up with all of the other maintenance items for your G3....like myself....it's not a spring chicken anymore..... ;)
  8. jerrymildred
    jerrymildred Senior Member
    11,517
    14,152
    Tampa, FL
    That's an easy one. We all make mistakes. Handling them well is what makes the difference. They stumbled, but fixed it. I'd stick with them.
  9. cnc97
    cnc97 Senior Member
    1,422
    1,535
    38
    Evansville, IN
    The initial concern was the different filter media part number for the filter itself. However, the filters are identical in every measurement. The Scion filter comes with the plastic drain spout for the filter housing. Not necessarily needed on when mounted on the Prius.
  10. xliderider
    8,140
    3,276
    Honolulu, HI
    Yes, the reason the plastic drain spout isn't needed on the Prius is that the filter is mounted horizontally, vs vertically on the Scion.
  11. DOHCtor
    DOHCtor Member
    162
    93
    Levis (Quebec city's south shore)
    2024 Prius Prime
    SE
    It was torqued like there is no tomorrow. I sell a lot of those. Rarely at the service dept. except if the car had an oil change at a small shop before. The thing is, the O-Ring does seal the thing. The is no need to screw that that much..
  12. MidwesternBlackSheep
    MidwesternBlackSheep Junior Member
    Manhattan,Kansas
    2019 Prius
    LE AWD-e
    They overtightened it, they should eat it.
  13. Mendel Leisk
    41,463
    C’mon isn’t it enough to just replace it? :ROFLMAO:
    Merkey and dig4dirt like this.
  14. MidwesternBlackSheep
    Manhattan,Kansas
    2019 Prius
    LE AWD-e
    Apologies. At my dealership “eat it” pretty much means pay for the repair.
    Merkey and Mendel Leisk like this.
  15. Gokhan
    Gokhan Senior Member
    6,217
    2,465
    Paramount CA
    It is not the fault of the guy trying to remove it, but it's the fault of whoever overtightened it. You need to pay for it because you took it to a different place this time. If you had taken it to the old place, they would have paid for it.
  16. Mendel Leisk
    41,463
    Think it was just one place involved:
  17. Gokhan
    6,217
    2,465
    Paramount CA
    In that case, it's their fault and responsibility to pay for it. The oil-filter caps are designed to last forever if they are properly tightened.
  18. ChapmanF
    18,214
    I thought the controversy had moved on to whether they should eat it.
  19. Mendel Leisk
    41,463
    The US prices are steep. When I did the conversion to spin-on, all-in price was just under $80 USD.
  20. Gokhan
    6,217
    2,465
    Paramount CA
    It's interesting that Canadian parts are shipped from the UAE! That probably doesn't include the Canadian sales tax. It's about the same price here—$73.66 plus 10.25% tax for the bracket. Remember that the prices may have increased since you bought it.
    https://parts.culvercitytoyota.com/p/Toyota__Three/BRACKET-SUB-ASSEMBLY---OIL-FILTER/78451942/156090T070.html
