Techron fuel system cleaner question.
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Michael Bones, Aug 25, 2019.
  1. Michael Bones
    Michael Bones Junior Member
    42
    Los Angeles
    Hi folks. It's me Mike the newbie again. I have a quick question. After I magically fixed my poor mileage issue by only resetting the system with a 2 minute quick disconnect of the 12 volt battery (went from 26.5 to 43.8 mpg) I now have decided to see if I can clean the injectors out a bit. So I bought a bottle of Techron fuel system cleaner at Walmart today. It says this bottle treats up to a 15 gallon system. Should I just dump the whole thing into my prius or is a full bottle overkill for such a small tank. I've put 50k on the car myself without doing a fuel system cleaning but this weekend I replaced the plugs,cleaned the throttle body,replaced the air intake filter and did an oil change. Final thing is the fuel system cleaning. I'm hoping to boost the mpg to over 46 mpg like I used to get when I bought the car three years ago. I normally just buy Arco gas because it is about 1 block from my house and the cheapest. Would there be any advantage to finding a Chevron somewhere and filling the car up with premium and then adding the fuel system cleaner or would it be overkill. What do you guys think?
  2. jb in NE
    jb in NE Senior Member
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    Use the entire bottle. Without the premium fuel.
  3. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    If you use Top Tier gasoline, you don't need the Techron. If you are buying no name gas, it sounds like a good idea every 50,000 miles.
    Homepage
  4. Michael Bones
    42
    Los Angeles
    Thanks guys. I really appreciate the input. Every mpg counts when you are doing ride share full time if you know what I mean.
    Take care,
    Mike
    Navitas likes this.
  5. Merkey
    Merkey Active Member
    321
    292
    Birmingham, Michigan
    I buy top tier gas and Techron at Costco. Lowest prices around.
  6. jzchen
    jzchen Newbie!
    3,316
    1,021
    Arcadia, CA
    ARCO is Top Tier. I say pass on the Techron.
