Techron high mileage
Discussion in 'Gen 2 Prius Main Forum' started by bluecrazymonkey, Jul 7, 2025.
  1. bluecrazymonkey
    bluecrazymonkey New Member
    26
    Earth
    hey guys new to the prius world. i got a 2008 104k miles i bought a month ago. i just recently used a techron high mileage fuel cleaner and ever since i used it? it seems like my prius cycles a bit more erratically as well as more often cycles. i also can see i get more green bars alot more even while driving uphill
    does anyone know why or has this happened to anyone else? did i mess up my prius? its kind of getting on my nerves.
    my prius does not burn oil either
  2. pasadena_commut
    pasadena_commut Senior Member
    3,028
    939
    Southern California
    One bottle of Techron is unlikely to screw anything up.
    If you have only owned the car for a month how do you know it doesn't burn oil? Mine does, a little, but I would have to drive it a lot to see the difference in one month - like a thousand miles, and even then only if it was parked in exactly the same spot and measured both times after sitting unused over night.
  3. bluecrazymonkey
    26
    Earth
    im a delivery driver so i check often. it goes down slightly overtime
  4. Merkey
    Merkey Active Member
    328
    301
    Birmingham, Michigan
    I've used Techron concentrate for years on both my Gen 2 & 3. Even more than recommended. Never had a problem. Had 225K miles on the Gen 2 and currently 175K miles on the Gen 3. Some might say i'm wasting money but that's OK.
