Techstream after replacing brake booster bleed issues
Discussion in 'Gen 3 Prius Technical Discussion' started by bagn, Jul 12, 2022.
  1. bagn
    bagn New Member
    FL
    Hi guys.. here is my issue... I replaced the brake booster and then went to bleed the bakes using tecstream. I get to the brake bleed utility and start. It immediately comes up with the box saying brake bleed failed. I followed the instructions... ie brake on... car on without ready.... unplugged the fluid level sensor .... and still it doesnt work. Do i have to reset the memory and do a relearn too?? i got a replacement boster with all the same letters LC and same serial numbers.
  2. ChapmanF
    19,027
    I've used Techstream (same laptop, same software) with two different dongles on my Gen 3, one of which could do the brake bleed procedure without incident, while the other one had lots of, um, incidents.
  3. bagn
    bagn New Member
    FL
    thanks... I guess I need a new dongle LOL
  4. bagn
    bagn New Member
    FL
    finally got it to work... and ermm looks like the "new" booster is not so new... now i have low pressure codes as well as accumulator leaking.. time to take part off and return it!
  5. ASRDogman
    ASRDogman Senior Member
    8,066
    4,089
    Used brakes parts are not really a good idea....
    I hope you can get it working soon.
  6. Jsninja650
    Jsninja650 Junior Member
    Florida USA
    Did you check with the dealer to see if it’s covered under warranty?
