techstream and cable
Discussion in 'Gen 3 Prius Accessories and Modifications' started by kiseattle, Oct 7, 2012.
  1. kiseattle
    kiseattle New Member
    Northwest
    Bought it from ebay. Finish all installation and is
    Running on vista.
    When i plug it in. All is yellow highlighted
    which mean the ecu is unknown?
    Anyone know why?
    I have a 2010 Prius and want to disable
    the seat belt chime
  2. PriusCamper
    PriusCamper Senior Member
    13,467
    5,435
    Pacific Northwest, USA
    Vista is really problematic operating system... Can you try it on a win7 or winXP machine that has been cleaned out and has all windows updates?
  3. kiseattle
    Northwest
    I have heard windows 7 64bits can't run this program. is that right ? I will try it on my other laptop first
  4. PriusCamper
    13,467
    5,435
    yes... that makes sense... though I think there's a workaround for that... As in a virtual machine / emulator...
  5. kiseattle
    Northwest
    ok , now I am stuck on the customize function menu. I can't go any further.
  6. vincent1449p
    vincent1449p Active Member
    894
    332
    Singapore
    Techstream can run on Windows 7 64 bit but the problem is the driver for the cable only comes with 32 bit. I 've no problem running with W7 32 bit.
    Can you take a screenshot?
    Vincent
  7. kiseattle
    Northwest
    yes .
  8. vincent1449p
    894
    332
    Singapore
    What is the version of your Java? There are some errors or abnormal operation if Java software is not installed, has become corrupt, or version is too old. Installing the latest version of Java (v1.6 - Update 7, minimum) from java.com: Java + You will resolve this issue.
    Your ver. 7.20.037 was also known to have conflict with Mozilla Firefox. If you 're running Firefox, close it and edit your registry:
    [HKEY_LOCAL_MACHINE\SOFTWARE\Mozilla]
    To:
    [HKEY_LOCAL_MACHINE\SOFTWARE\Mozilla_X] (for example...)
    Then install TS as usual. After finished install, rename back your registry to original.
    Vincent
    PriusCamper and edthefox5 like this.
  9. kiseattle
    Northwest
    Thanks Vincent. I will try it tonight.
    And just want to make sure , this kits I bought it from ebay is able to disable seat belt chime right ?
    And now is just my computer/software issue?
  10. Youngguns09
    Youngguns09 New Member
    Brisbane, Queensland, Australia
    2013 Prius v wagon
    just wanted to ask ... is Techstream program works with Prius v released here in Australia....
    Thanks
  11. gliderman
    gliderman Active Member
    751
    225
    Should work with all toyotas.
  12. vincent1449p
    894
    332
    Singapore
    Depending on your version, the latest release has full support for 2013 and earlier model years + some new 2014 model years.
    There is a region setting for different countries; NA, EU, JP, Others, make sure you select Others.
    Vincent
