Techstream EGR Valve Blockage Data
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by jas8908, May 3, 2019.
  1. ChapmanF
    19,019
    Ordinary PIDs for live data are read using OBD-II Mode 1. Monitor results like for the EGR flow test are read using Mode 6.
    I don't know specifically whether Torque Pro has features for reading Mode 6 data, but if it does, you probably have some other way to set them up, not exactly the same as Mode 1 PIDs.
  2. burebista
    burebista Active Member
    189
    130
    Romania
    It has. I don't recall where from top of my head now because I'm using Car Scanner app but for sure is not a custom PID.
  3. burebista
    189
    130
    Romania
    Found it. It's in Test results.
  4. Ohid
    Ohid Member
    157
    Dhaka, Bangladesh
    2015 Prius Alpha
    T
    Thanks. Is it from Car Scanner or Torque pro?
  5. Ohid
    Ohid Member
    157
    Dhaka, Bangladesh
    2015 Prius Alpha
    Torque pro notify me ECU not support mode $06.
  6. ChapmanF
    19,019
    I wonder if the version sold in Bangladesh lacks that support.
  7. Ohid
    Ohid Member
    157
    Dhaka, Bangladesh
    2015 Prius Alpha
    Its Japanese Prius Alpha 2015, 7 seater.
  8. burebista
    189
    130
    Romania
    Japanese Prius don't have that 06 mode. :(
    You are the second one on this forum that I know with this problem.
  9. Ohid
    Ohid Member
    157
    Dhaka, Bangladesh
    2015 Prius Alpha
    Other Prius Alpha users can varify it.
  10. ChapmanF
    19,019
    Little follow-up. When I replaced my EGR valve and cooler a year ago at around 155k miles, the monitor result went from 10 point something kPa up to 21 point something.
    But it took me this long to get around to opening the old EGR valve, and lo and behold, it revealed mashed ski-jump syndrome (though not as bad as ozmatt's, which was causing a P0401 code).
    So this seems to be something to check on any used EGR valve. And my before-cleaning 10 point something kPa result was not only due to clogging of passages. It was some combination of the passage clogging and the misindexing of the valve.
    Frustratingly, the valve was in pretty fine condition, otherwise.
    #230 ChapmanF, Aug 22, 2022
    Ohid likes this.
  11. mtl
    mtl Junior Member
    55
    24
    Slovenia
    Sorry for resurecting this old post. Where exactly in TIS do I get this view and info?
  12. Bill Norton
    Bill Norton Senior Member
    2,243
    754
    MONW, Ks.
    2019 Prius
    L Eco
    And just to review this thread,, Can this function be done with Torque app?
    Or does it need techstream?
    I like getting technical and not digging into the EGR system cleaning if it's not required.
    Thanks for any guidance!
    Is there a way to get an independent shop to run this quick test , and not try to get a dealership to run it?
  13. ChapmanF
    19,019
    I believe post #58 in this thread showed the value being retrieved with Torque.
    "Mode 6" emission monitor results are a standard OBD-II feature. You can see examples in this thread of many different OBD readers being able to retrieve them. If whatever tool you are using says it can retrieve Mode 6 results, you should be good to go.
  14. burebista
    189
    130
    Romania
    Just a couple posts above I put a screenshot from Torque Pro. :)
    Bill Norton likes this.
  15. CR94
    CR94 Senior Member
    2,829
    1,242
    Northwestern S.C.
    Yeah, that's why, based on decent flow test result, I'm procrastinating digging into the EGR cooler. However, even if your flow test result is ok, "digging into the EGR system" as far as the EGR ports of the intake manifold might still be prudent. If the passage to one or two cylinders is clogged, they'll receive no EGR and the others will receive too much. The overall flow test won't reveal that imbalance. Fortunately, the manifold is easier to get off than the cooler is.
    mtl and Bill Norton like this.
  16. Bill Norton
    2,243
    754
    MONW, Ks.
    2019 Prius
    L Eco
    Dang it,,,, you are so right!
    I guess I need to do this work sometime in the future.
    I'll probably do it all at once when I go for it.
    So what are your thoughts on the original intake manifold vs the new design?
    Is it worth buying the newer one?
    But then,,, I'll be P'd if at 220k miles I need to replace the head gasket because it's just a P'Poor design of the block/head/gasket.
    And this whole "You must keep your EGR System clean" is all just a myth.
    The silence from the company must say something.....
  17. mtl
    mtl Junior Member
    55
    24
    Slovenia
    Exactly, that is why I have done intake manifold cleaning and while at it I have also replaced the PCV valve and cleaned the throttle body. I was very surprised that my car at 90.000 miles was very clean and also there was no oil under the throttle body, so it should be in great shape.
    CR94 likes this.
  18. Raygon
    Raygon Junior Member
    I just went outside and ran mine to see what are my values are. first of all looks like Car Scanner fixed issued as the values are display in kPA.
    value 19.86 kPA
    Min. 0.99 kPA
    Max. 655.35 kPA
    Mine is a 2011 with 160K, and recently cleaned the intake manifold, EGR Valve, pipe and EGR radiator.
    I want to say thanks to all for all the knowledgable info you guys post!
  19. Steelholder
    Steelholder Junior Member
    73
    17
    Encino
    When using the car scanner app on an android under what conditions is this test done? Car turned on idling? While driving? I keep running this test but get no values.
  20. CR94
    CR94 Senior Member
    2,829
    1,242
    Northwestern S.C.
    Not critical. I do it in "ON" mode (not accessory mode as I said here earlier), i.e., car parked and not "READY."
    #240 CR94, Nov 6, 2022
