Techstream error when registering TPMS sensor IDs
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by BigFan, Nov 26, 2016.
  1. wjtracy
    wjtracy Senior Member
    11,374
    3,609
    Northern VA (NoVA)
    Yes check that out, I just had bent pins on a computer monitor plug, which is what made me think of that.
    PS- No my pins do not seem to stick out.
    #21 wjtracy, Dec 2, 2016
  2. BigFan
    BigFan Member
    156
    66
    New Jersey, USA
    Thanks for checking your cable. I have reached out to my vendor (who to date has been very responsive) regarding the two pins being pulled forward of the rest (I have never seen a cable with that type of design, but do not have much auto experience.) The picture below highlights the two pins that are pulled forward from the rest. Let's see if that is the cause of my troubles.
    #22 BigFan, Dec 2, 2016
    Prodigyplace likes this.
  3. Mendel Leisk
    42,271
    Can they be pushed back a little? Those are likely the power pins; that's pretty much the only pins I have on an OBD memory saver cable.
  4. BigFan
    BigFan Member
    156
    66
    New Jersey, USA
    No these pins will not move. I think they are soldered in position (taking the cover off the connector).
    Also the data I have indicates pins #4 and #5 are Chassis and Signal Ground, respectively (Google "toyota dlc3 pinout")
  5. Mendel Leisk
    42,271
    Hmm, I do have third pin on my memory saver, lower left corner of pic. Maybe that's 12 volt.
  6. BigFan
    BigFan Member
    156
    66
    New Jersey, USA
    My data indicates pin #16 is 12v., so you are correct.
    Prodigyplace and Mendel Leisk like this.
  7. Mendel Leisk
    42,271
  8. bhtooefr
    bhtooefr Senior Member
    1,396
    1,489
    Newark, OH, USA
    Extending the ground pins is a common strategy for a connector that's intended to be hotplugged. That way, you connect the grounds first, so the connector is grounded before the rest makes contact. Makes things safer for things on both sides of the connection that way. USB, SATA, and a few other connections use the same technique.
    kithmo likes this.
  9. Prodigyplace
    12,710
    11,848
    Central Virginia
    The mating connector has to be designed to accept that, though. Otherwise some of the other pins may not make proper connection.
  10. BigFan
    BigFan Member
    156
    66
    New Jersey, USA
    Exactly, so the question is does the Toyota DLC3 connector (OBD-II) designed for offset ground pins?
  11. bhtooefr
    1,396
    1,489
    Newark, OH, USA
    Offset ground pins are required by the SAE J1962 and ISO/DIS 15031-3 specifications. So, anything OBD-II is required to handle that.
    RCO, Prodigyplace and Mendel Leisk like this.
  12. BigFan
    BigFan Member
    156
    66
    New Jersey, USA
    Thanks for that definitive response. So it seems my connector with the offset ground pins is not by accident,
  13. wjtracy
    11,374
    3,609
    Northern VA (NoVA)
    Yes upon closer exam mine has that too, after I saw the pic I thought I better look again, sorry about that.
  14. BigFan
    BigFan Member
    156
    66
    New Jersey, USA
    No worries (ya giver of false hope!) :)
  15. wjtracy
    11,374
    3,609
    Northern VA (NoVA)
    There have definitely been reports of bad older joints inside the connector, on Amazon, and I think we have had at least one person here with a faulty miniVCI connector. Yours looked maybe better quality than some of the $20 knock-offs from Amazon/EBay.
    acadiel likes this.
  16. Max_B
    Max_B Junior Member
    French Alps
    2023 Prius Prime
    Hello there,
    Bumping this thread after I found it googling for the exact same situation as the OP. It is on a 2017 Prius Prime (PHV in Europe).
    Thank you for posting the Toyota instructions for this situation. I did not try to short the two pin yet, will try tomorrow.
    Did you, BigFan, eventually sort it out ? Being the same kind of engineer, I'll not give up on it after I bought 4 genuine Toyota TPMS for my winter wheels. In the worst case, I'll go to Toyota service to have it done, but it's a long drive away and that's why I bought a mini-VCI in the first place.
  17. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    Sorry I can't answer your questions, but welcome to Prius Chat. Guaranteed it won't be long before someone comes in with a bit more help.
  18. Max_B
    Max_B Junior Member
    French Alps
    2023 Prius Prime
    Well, I had some hope when I found a thread on a Lexus forum (no link allowed yet). But had no luck to succeed, even using the workaround of powering the laptop and adding an usb hub to give more power to the mini-VCI. Several reports on the web for failure to set TPMS IDs with TS. Looks like I'll have to go to a Toyota dealer to set theses IDs in.
  19. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,094
    Columbia, SC
    I noticed the original post mentioned a communication issue. I've had similar errors with communication "problems" using my TS (10.30.029) and I'm able to eliminate it by doing a complete ECU health check first. Now, every time I go online with a car, the first thing I do is a complete health check. Following the health check, it shows that each ECU has been identified and communicated with. (each ECU changes from white to yellow, if I remember correctly). Then I go about performing whatever else I need to do.
    RCO likes this.
  20. Raelx
    Raelx Junior Member
    Bethel, CT
    Exact same problem here with a 2017 Prius Prime. I'm trying to connect to OE Toyota sensors from a 2010 Prius, but i think this discussion has gotten to the point we believe the issue in the TS and the sensors.
    Also worth pointing out that i have used this exact same setup (laptop w/TS 12.00.127 + mini VCi from ebay) to change the TPMS registration on my 2015 Sienna with zero problems. So this seems to be a problem with newer MY vehicles or possible Prius specific?
