Techstream Key for software #DC16118B6C261910B3B70DEF8DCDA400?
Discussion in 'Gen 2 Prius Main Forum' started by Gino Veltri, Aug 18, 2022.
  1. Gino Veltri
    Gino Veltri Member
    412
    40
    Can anyone help me out in getting a new key for my techstream software. Im trying to install it on a new computer but am blocked by this key.
    Software #: DC16118B6C261910B3B70DEF8DCDA400
    North America
    Techstream 17.00.02
    Windows 7 32 bit using MiniVCI cable
    #1 Gino Veltri, Aug 18, 2022
  2. Tombukt2
    Tombukt2 Senior Member
    12,215
    2,155
    Durham NC
    Wow 17 version software I haven't seen that mine's like 15.6.
  3. Gino Veltri
    Gino Veltri Member
    412
    40
  4. douglasjre
    douglasjre Senior Member
    2,097
    701
    Null, NL
    contact one of the ebay sellers who do this regularly
  5. Gino Veltri
    Gino Veltri Member
    412
    40
    Tried from the Amazon seller I bought the mini vci from. No response with a key
  6. Elektroingenieur
    2,515
    3,277
    Three Touring
    With a Professional Diagnostic subscription to techinfo.toyota.com, from $65 for two days, you’d get access to download a slightly newer version of the Techstream software and to calculate a key to enable it. The key expires at the end of the subscription, however.
  7. Gino Veltri
    Gino Veltri Member
    412
    40
    I just had a member provide me a key from a website but it was for a different software # (somehow). It worked but now I’m trying to install on a different windows 7 computer..
  8. Tombukt2
    12,215
    2,155
    Durham NC
    Aw jeez . Get to one machine . Then go from they're . I'd say . Was there an issue with the other machine that wouldn't allow it to work properly I mean if you can get to where you enter the key I would say the softwares installed and should work you just don't have what a key That's a problem so they're really aversion 17 with text stream right now My god I just bought mine a year and a half ago and it was only a 15-5 or something I guess they change the stuff a lot either way none of it seems to get me faster it all runs about the same I'm looking at the dealers latest version right now and the service department and it's on a similar looking tough book type thing haven't even graduated a tablets yet at the dealer and it seems about as slow as my mess so it doesn't seem like. Much has changed.
  9. Gino Veltri
    Gino Veltri Member
    412
    40
    i would say so too. In fact it was the amazon seller (of the mini VCI) who said it wont work on windows 8.1. I also encountered an "unable to connect to VIM" error.
  10. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,353
    2,347
    Taylors, SC
    Try turming off WiFi on your computer. There is no sign on screen asking for an account number, if WiFi is not enabled,
    You won't be able to access all on line Toyota services, but you cab do most all Techstream applications.
  11. lexidium
    lexidium Active Member
    284
    133
    manchester
  12. alftoy
    alftoy Senior Member
    1,132
    514
    Saskatchewan, Canada
    Link error.
    #13 alftoy, Aug 19, 2022
  13. Gino Veltri
    Gino Veltri Member
    412
    40
    I don’t think Wi-Fi is on. It asks me for the key either way. I just to read a sub code nothing fancy
  14. Tombukt2
    12,215
    2,155
    Durham NC
    And when it asks you this or it could actually tells you doesn't and it tells you you will have limited usability or something and it's something's in red and I click stay and offline mode and then everything works just as it should it's just not logged into Toyota and grabbing the latest updates for whatever car unplugged into and that's just fine.
  15. lexidium
    284
    133
    manchester
  16. lexidium
    284
    133
    manchester
    Don't know what's happening. It won't accept the link.
    Just try typing it into your browser
  17. prius16
    prius16 Active Member
    462
    243
    New England
    2022 Prius Prime
    Or, copy/paste below.
    Code:
    http://bob123.f2s.com/techstream15.zip
  18. alftoy
    1,132
    514
    Use without http://
  19. Gino Veltri
    Gino Veltri Member
    412
    40
    gotcha thanks. I got the car up and running with no codes and ordered a replacement cable. But still running into unable to connect to VIM. I guess ill uninstall and start over.
    Is anyone familiar with the steps to get techstream working? There are 1000 different contradictory instructions online, then the one the little cd came with (only theres no key). Is there an order i need to install in? Techstream, then driver, then patch?
    Also does anyone have a x32 bit driver / patch? Do i need a seperate install to get the computer to recognize the cable?
    This is incredibly frustrating, every year i spend like a month trying to get techstream to work. Have never succeeded.
