Techstream/Mini Vci and DIY Maintenance
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Mobalized, Sep 16, 2013.
  1. Mobalized
    Mobalized Member
    98
    27
    So I have read a few threads about Techstream and Mini VCI but want to verify before I make any purchases. I do all my maintenance on my cars myself, from oil to engine changes, and I desire to be able to do the same with the prius. I have a 2012 and would like to plan for the future in terms of being able to do brakes and what not. The question is will Mini VCI from ebay be able to run on a windows 7 64 bit system and allow me to control solenoids, etc for brake changes and bleeding?
    Isaac Zachary likes this.
  2. Britprius
    Britprius Senior Member
    5,194
    1,922
    Herefordshire England
    I have the Mini VCI and am unable to get it running on windows 7 64 bit, even in compatibility mode for XP or Vista. It runs fine on two older laptops with Vista and XP. The user manual states it is for :- Win98/ XP / 2000 / Vista. It is able to control just about everything.
    John (Britprius)
  3. Mobalized
    Mobalized Member
    98
    27
    Have you tried xp virtual machine?
  4. Britprius
    5,194
    1,922
    No not come across that. Hows that work? Not that I need it as I use my ancient (14 years) IBM laptop for my car work as it saves knocking my new laptop about.
    John (Britprius)
  5. Onex Prius
    Onex Prius Junior Member
    Puget Sound WA
    I'm running Techstream 8.20.019 on Windows 7 64bit perfectly fine. In native 64bit mode. But my cable is Mongoose MFC VIM.
  6. Mobalized
    Mobalized Member
    98
    27
    Google "Windows Virtual Machine" and follow the microsoft links.
  7. mikeuk
    mikeuk New Member
    uk
    Hi you need to get V11.10.034 it is for X64, mine runs on windows 10
  8. fopoku2k2
    fopoku2k2 Member
    292
    60
    Columbus - Ohio
    can you share your copy with me??
  9. StarCaller
    StarCaller Senior Member
    1,283
    732
    Cedar Crest, NM, USA
    #9 StarCaller, Jun 23, 2017
  10. 4md
    4md Member
    97
    55
    Sofia, BG
    Here is the step-by-step tutorial how to run it under x64 Windows. The registry modification step is required to get Techstream use the XHorse drivers (Setup -> VIM Select -> Interface setup: XHorse - VCI):
    Techstream TIS VCI Installation Guide (64-bit OS)
    Using this tutorial I managed to run it under Win10 x64 and it works fine.
