Techstream: on Virtual Machine vs installed
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Phaul80, Jul 23, 2025.
  1. Phaul80
    Phaul80 Junior Member
    32
    New Orleans, LA
    I have techstream on a virtual machine on my laptop. Works for most things, but the air bleed process takes several tries.
    When i first got my j2534 cable from amazon, it came with a cracked version on a cd. i installed onto a nuked laptop that i didnt care about, and it worked fine til the laptop died completely. I found a virtual installation and have been using that to do this latest brake actuator replacement.
    Could the extra layer between the obd2 port and the virtual machine cause issues with the ABS initialization? Theres so many valves and solenoids that are engaged, i wonder if split second delays could cause issues
  2. mr_guy_mann
    mr_guy_mann Senior Member
    4,118
    2,015
    NJ-USA
    It's possible.
    There also are several versions of the OBD2 cable out there with various reports of erratic functionality. Some "work just fine", others have faults when attempting bidirectional procedures or tests (such as brake bleeding).
    As always, it's a good idea to key a battery charger on the 12V while doing ABS bleed - relearn functions,
    ccna101 likes this.
  3. ccna101
    ccna101 Member
    122
    29
    SFO/IAD/DCA
    2020 Prius Prime
    I am second the above note... have dedicate battery charger during the ABS proceed !
    Next is Gen2 is ABS quite finicky ... just having a wrong step at a wrong time will give you plenty of surprise ...
    What kind of issue you having ? screenshoot will help since you dealing with TS ... blockout your VIN.
