Techstream problem For JDM Lexus GS450H
Discussion in 'Lexus Hybrids and EVs' started by Wenjun Li, Aug 31, 2020.
  1. Wenjun Li
    Wenjun Li Junior Member
    tauranga
    I recently got a MINI VCI kit and hoping info. from techstream can help my with my battery rebuild. I can connect and read codes, but no data showing for Hybrid control. A fatal error kept popping up.
    There are a lot of variables in my setup that could've caused the issue, I need help to allocate which one or ones:
    The Car is a JDM, Do I need a certain TS version to work with it?
    All threads I have been reading are for Prius, Is it a common Lexus Problem?
    I am running a virtual XP 32bit on my Surface Pro as the host, may this cause any issue?
    Is the kit I bought not good enough?
    The versions I had tried were anything between 12.x.x to 15.x.x, should I try earlier ones?
    Big thanks for any input
    Regards
    Jonas
