Techstream shows battery voltage and SOC not in sync
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by ilbdarned5, Jul 16, 2025.
  1. ilbdarned5
    ilbdarned5 Junior Member
    Blanchard, Oklahoma
    My battery charge display would sometimes show only 1 bar and randomly I would throw a generic P300 and P080 code.
    If I unplugged the battery module to reset it,( without the engine starting to charge the battery),when I power up the car the bars on the display would jump up to show a full charge.
    I realized at that point my SOC ( state of charge) in bars on my display was not showing to be in sync with the actual HV battery voltage. The bars seemed to stick sometimes throwing the codes.
    Since the HV battery module senses the battery voltage by using 14 inputs, and the input voltages are reading normal, but the SOC did not follow the voltage changes in the charge and discharge cycles. I am assuming the module is bad.
    The HV battery module seems to communicate % of battery SOC to the can bus system instead of battery voltage.
    I am assuming the module is bad, guess I will try changing it but I probably need to check the CAN BUS Pins on the battery HV Module and Main module first to see if the fault could be by a bad can bus connection.
    My question is, if all connections between the modules are good, when the battery voltage and SOC of the battery are not staying in sync, would that be a problem in the HV battery Module?
  2. ilbdarned5
    Blanchard, Oklahoma
    I meant my car was throwing a P3000 code not P300
  3. mr_guy_mann
    mr_guy_mann Senior Member
    4,118
    2,015
    NJ-USA
    When you disconnect the 12V battery, you reset the high voltage ecu (ie, give it "amnesia"). The default value for SOC is 60%, and it takes some operational time (ie driving) before the ecu can relearn the correct value.
    P3000 and P0A80 together likely indicate a failing battery module. Looking at freezeframe data from the code can help narrow down where the problem is.
    Often a bad battery module will show as a block that has 1.0 - 1.5V lower than the rest when accelerating hard
    Brian1954 likes this.
  4. Brian1954
    Brian1954 Senior Member
    2,689
    1,075
    South Central PA, USA
    What year is your Prius, and how many miles?
    Has the hybrid battery ever had work done on it, or has it been replaced before?
  5. ChapmanF
    19,033
    Although it's generally true that the overall voltage is higher at higher states of charge, there isn't a simple relationship. The curve relating the two is pretty close to flat for a spell in the middle.
    The battery ECU also monitors a current sensor, so it can track the coulombs of charge in and out of the battery, for a better idea of what the state of charge is at a given time. When memory power is lost, that gets forgotten, and then the ECU has to start off with a rough guess of SoC only based on the voltage.
  6. ilbdarned5
    Blanchard, Oklahoma
    Thanks Brian for your input.
    The ECM has a set time it takes to do some readings like 02 sensor readings, not sure about SOC I have over 330k miles on my Prius and that is because I know how to recondition the HV Batteries, People act as if it is rocket science, but it is all volts and amps simplified, you have to have enough of both and they need to be balanced since all cells are in series and one bad one can effect the whole package be it low volts or low amp hr capacity.
    I am not sure what is normal when the car is charging right, but when the SOC can be high when the voltage is low and lower when the voltage is high, something is not communicating to the charging system what it needs to do to maintain the HV charge.
    My display can show no bars with my battery fully charged so I suspect a module or a wiring issue like short or bad connection in either a module of the 4 that control the charge, or in the CAN BUS wiring.
    Today I did a bus check with Techstream, it showed all the modules that work to manage the HV charging and all were shaded red which meant no communication. So since changing the HV battery ECU did not fix the problem and I have a HV controller ECU coming to replace, if that does not fix it , next will be troubleshooting the CAN BUS communications.
    You can't get up to 53mpg one day, then randomly throw the death code and get in the 30s mpg, then another day get 53 again and it be a battery issue.
    I will figure this out, no doubt to me, I do not give up. When I do I will post the solution here. But people that always jump to condemning batteries only do it because these systems are too hard for most people to troubleshoot so as a first resort they condemn the HV battery.
    I will come back here when I figure it out, it has been so hot and humid I have not felt like troubleshooting wiring yet in this weather, just doing component changes of the most likely problems for now as a process of elimination. The modules are cheap and if not needed I will always have a back up. I have rebuilt the combination meter on this car too, before when I bought it, it would not even start. It has been a great car.
  7. Brian1954
    2,689
    1,075
    The next time you get warning lights on the dashboard, use Techstream to run a Health Check and post pictures of the results in this thread. If you have the P0A80 code, double-click on the "snowflake" to look at the freeze frame data. Post pictures of the freeze frame data.
    The reason you are seeing this behavior is explained in post #3.
    #7 Brian1954, Jul 24, 2025
  8. ilbdarned5
    Blanchard, Oklahoma
    I think I am chasing symptoms, not the problem as far as the SOC not matching the actual battery charge. I troubleshooted the CAN BUS and voltages are good.
    So anyway I found a problem just by happenstance yesterday.
    In the past when I did not have this HV charging problem, out of curiosity with the ignition off I had checked the high voltage terminals from the battery at each of the 2 relays to vehicle ground. I just wanted to know if the HV battery was grounded to the frame for safety purposes. It was not, it was totally isolated logically as you would expect.
    So yesterday as I was screwing around after checking the CAN BUS, I set my meter to 1000v, had the safety plug unplugged and with my meter negative lead to ground I touched the positive lead to each HV battery cable at the relays, so one cable comes from the positive of the battery and one from the negative on the side facing the front of the car
    I was getting voltage readings from ground at each terminal, one a higher voltage than the other.
    I noticed when touching the negative meter lead to vehicle ground and the positive lead to the battery negative cable, I was reading negative voltage which meant positive from the battery was shorting to vehicle ground somewhere.
    Touching the positive meter lead to the positive cable from the HV battery and the negative meter lead to ground, I was getting a positive voltage reading, which meant HV battery negative was shorting to ground somewhere.
    The 2 different voltage readings of different polarity to ground were because the battery was split into 2 packs by the safety plug being unplugged. So since the only other wires connected to the cells were the monitoring wires I determined that is where the leak was traveling through to vehicle ground somewhere further down the line.
    Prior I had tried 3 different HV battery modules that I had, 2 had been tested one was the original and nothing changed, so I knew the leak was not battery module to ground.
    While watching the HV battery voltage to ground I unplugged the plug on the rear side of the battery to the battery ECU, and the voltage dropped out rather quickly, at that point I knew I needed a wiring diagram to isolate which wire(s) in the plug were carrying the short(s) to ground.
    I know that one thing the module output plug feeds is the battery cooling fan, but it seems to be working fine tested using Techstream. I will isolate the wires next to see where the shorting is.
    One thing I did not mention with all my babbling is the HV reading to ground would very slowly start dropping after the ignition was turned off, this I recognize as a solid state type leakage because it seems like a resistive short, not immediate like a dead short to ground.
    It is possible I could have a bad HV control module with an internal short, or a wire feeding it is grounded to frame and the short is traveling through some of the solid state components like a capacitor back to the HV Battery module.
    The reason I write so much so detailed is so if others have this issue they can glean more about the troubleshooting process. Sorry it is so much to read.
    I will follow up on this soon I have an HV control module being delivered soon, I will try replacing it before I do further wire tracing, in the case my HV control module is the problem,
    that would seem logical as the problem in a non Murphey's Law world..
    #8 ilbdarned5, Jul 25, 2025
  9. ilbdarned5
    Blanchard, Oklahoma
    I just saw your instructions today Friday, codes were cleared while troubleshooting yesterday, and have not driven the car to set the P0A80 code again, I can tell you the code sets intermittently with random readings in the freeze frame but I am no expert on all aspects of freeze frame data reading so it is possible I could be missing something, just that nothing stood out as abnormal when the Code sets.
    I have not wanted to drive the car to set the code, as I have to put everything back in place so the cooling works and I was troubleshooting the wiring yesterday.
    I feel I am onto something with this HV short to ground within the charging system so I am going to finish the process and if it does not fix the problem I will work on getting and uploading the freeze frame data. Right now my time working on this is limited. But thanks a lot for your help and communication, two heads are better than one.
  10. ilbdarned5
    Blanchard, Oklahoma
    I am slow catching up on your very helpful post responses, but that makes sense kind of like how it takes time driving to set 02 codes for emissions.
    I sometimes think I could design a better component troubleshooter as most codes are vague and some are set by other issues, not what the code designates. Like the replace battery pack code is generic.
    My charging issue is causing my AC and my TRAC system to also throw codes because of the inverter control problems
  11. ChapmanF
    19,033
    In most cases, the other codes you're getting are the ones that mean you have a hybrid-system code reported. For example, you probably have a C1310 code from the traction control and/or a C1259 code from electronically-controlled braking, as described on our blink codes page. So it isn't weird to have those codes when you have a hybrid-vehicle code; it would be more weird not to have them, because that's what they mean.
    I think the designers pretty much program in trouble codes for conditions that are practical to detect based on the inputs the ECUs already have available (so, inputs that are needed for the normal functioning anyway). The brake/skid ECU knows when the HV control ECU is reporting codes, because the two ECUs have to communicate with each other about regen braking anyway.
    If a more-specific trouble code would require having additional sensors or bringing additional signals back to an ECU that it wouldn't need in normal operation, the designers generally say "nah, that can be left for a person to do when there's a problem to diagnose."
    But I often see people drawing too many conclusions from the short, one-liner "fortune cookie" that's associated with a trouble code. Really, figuring out what a trouble code 'means' involves going to the repair manual and reading the text (usually a paragraph or three) in the "detection condition" box. That'll say what conditions, actually visible in inputs available to the ECU, lead to the logging of that code. Armed with that knowledge, it's then easier to plot a diagnostic path forward.
