Techstream v14.30.023 Unable to connect to VIM - Windows 10 64-bit
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Hybrid GUID, Dec 17, 2019.
  1. Hybrid GUID
    Hybrid GUID New Member
    Virginia
    Hi Community,
    I purchased a VCI J2534 cable from ebay - itm:312736749898
    I installed the v14.20.019 that came in the CD, updated to the latest v14.30.023 and paid for a key to get it licensed.
    However, it wont let me connect to my vehicle. I get "unable to connect to VIM" error. I have tried switching Techstream configuration to Europe like some threads mention to no avail. Also, I don't have the XHorse option under VIM select like some older threads talk about. One thing I noticed is when running the Mini VCI Driver for TOYOTA.msi driver, I get a "The MVCI Driver for TOYOTA TIS Setup Wizard ended prematurely" error. I tried running the .msi driver installer from my users directory and C:\ directory to no avail.
    Anyone know how to get this running correctly?
    I have a Windows 10 64-bit machine.
  2. SFO
    SFO Senior Member
    5,302
    4,252
    Northern California
    ** Generally speaking, don't upgrade the firmware on the mini-vci cable/dongle. You also don't need the latest and greatest version of techstream for your current gen2, though some versions have features that others may not.
    Nice to see that you've entered the water with a full back flip and a double twist :whistle:
    Doubtful if this will be a simple drop down menu install. I've pulled off a winblows 7 install before, and I'm pretty sure 8 and 10 are equally as doable.
    Though we should have this sorted. In the future please use the advanced search feature within the forum, as it's currently working.
    Give the link below a shot, and let us know how it works out. Scroll down until you find " Techstream install windows 10: "
    https://blog.obdii365.com/2017/12/03/toyota-techstream-12-30-017-download-and-install/
    Good luck (y)
    Raytheeagle likes this.
  3. Travis Decker
    Travis Decker Active Member
    139
    116
    Portland OR
    The problem is the driver for the mini VCI cable there is a way to edit your configuration and get the driver to install on 64-bit windows. A buddy who is better with windows than I am did it for me in 5 minutes. It's just that you are trying to install a driver meant for 32-bit on 64-bit. Do some Google searching and you will figure it out
  4. ruggb
    ruggb Junior Member
    67
    Cary, NC, USA
    Travis, I want to talk to your friend. I am very familiar with Windoz and I have been unsuccessful for years in getting this to work with W10 x64. I have it working on W7 x32. I have tried EVERYTHING. Step-by-Step instructions, AutoKent, registry hacks, TS versions 8, 10, 12, 14, driver version 6, 10, 12, and a clean install of W10. Nothing works. The FUT absolutely doesn't work on x64. and the reference to is in the write-up for getting it to work on x64 makes me believe whoever wrote it has no clue.
  5. Hybrid GUID
    Virginia
    I decided to run it successfully on a virtual machine with XP Mode. The following tutorial shows how to do it on Hyper-V but can be done with VirtualBox or VMWare. (I can't post with URLs because I don't have 4 posts yet). Just Google or ahem, duckducksearch "install xpmode on hypervisor"
    Microsoft's website allows you to download XP Mode but wont be activated. The download allows you 30 days to get it activated. Just take a snapshot of it after you have Techstream installed and running correctly so you can revert back to your 30 day allowance whenever you need. Be sure to move any saved log files from the virtual machine to your host machine so you don't lose them when you revert back to the snapshot. Also, be sure to disable NAT or any other network adapters as Windows XP is no longer supported and is full of security vulnerabilities. If you use VirtualBox, be sure to install the extension pack version matching your VirtualBox.
    SFO and Happyandsadperson like this.
  6. rfelley
    rfelley Junior Member
    42
    Oregon
    I get a security warning when I click on that link.
  7. SFO
    SFO Senior Member
    5,302
    4,252
    Northern California
    Forgive me, but did you have any interest in entering sensitive information, like a CC or SS# on that website?
    If not, then you might try using a different browser, or just hit the "advanced" button, and allow an exemption for this session.
  8. ChapmanF
    19,050
    Or downloading software from it to run on your equipment?
  9. SFO
    SFO Senior Member
    5,302
    4,252
    Northern California
    I don't believe there is downloadable software being hosted on that website. Simply visiting or reading that website, or any other with a self signed / out of date SSL/TSL certificate isn't anything to be overly concerned about, even if drive-by downloads are real.
    Now if someone wanted to make an online purchase or enter personal details, they might want to take pause, and even if shenanigans presented themselves, it would only take a simple call to the CC company to sort out the unwanted account activity.
    Real world safety or risk thresholds vary per individual, some will never use online banking or even consider shoping online with a debit/CC, and others see no issue with doing either. This is why there are 'walled gardens' of all types, it takes the perceived risk out of the process. Though most will believe what big tech/brother tells them, it may not always be in their best interest.
    #9 SFO, Feb 21, 2021
  10. ChapmanF
    19,050
    I looked at the link ending in -download-and-install and a made an nice-person-umption.
  11. howardc64
    howardc64 Member
    147
    55
    Pacific Northwest
    Just installed the latest Techstream (v16.00.017, 2/2021) on Win10 on my several years old ebay Mini-VCI J2534 dongle. Also got stuck awhile with no VIM communication. Got it working. Here are some tips.
    A. Need 3 pieces of software : Techstream of course, a 64b VIM driver, a USB to serial driver for your dongle
    B. Used Autokent's 64b MVCI MultiDriver, search on mhhauto.com. Including drivers for several version of firmware on dongles. Install with admin permission on W10. Anti-virus will flag trojan but I told it to accept it. Never had a virus problem but its a Win10 partition I use strictly for electronics diagnostic purposes and no personal info.
    C. I read most Chinese Mini-VCI J2534 are FTDI chip so need their USB to serial driver. Here is the installer + page its on
    https://www.ftdichip.com/Drivers/CDM/CDM21228_Setup.zip
    VCP Drivers - FTDI (ftdichip.com)
    After installing this, Device Manager will show USB to Serial device (COM3 for me)
    D. Activate Techstream via various methods depending on where you got it from.
    E. After all 3 installed
    Run MultiDriver and install the a matching dongle firmware version driver. I just picked the latest
    Plug-in dongle, put Prius in accessory or ready mode
    Run Techstream and select the matching VIM version installed by MultiDriver
    Connect to vehicle
    I was stuck unable to communication to VIM without step C and worked fine afterwards.
    #11 howardc64, Apr 11, 2021
    SFO likes this.
  12. Gino Veltri
    Gino Veltri Member
    413
    40
    Thanks again! Now im trying to start over and install on a different laptop. This time Windows 7 32-bit system. Is the mini vcl specific to 64/86 bit systems because those are the drivers/patches that are on the cd.
