Tein htechs help...
Discussion in 'Prius c Accessories and Modifications' started by -y0-, Oct 30, 2016.
  1. -y0-
    -y0- Member
    142
    Pacific NW
    I recently got htechs installed and the driver side is lower and also there's a space on strut cover area. Not sure if that's supposed to be flush. I've attached pics for reference. Help?
  2. edspecR
    edspecR Member
    136
    94
    Berkeley
    not sure if this is still an issue, but an uneven drop is perfectly normal, especially for springs. by now they should've settled a smidge more, maybe they've evened out a little? the extra gap in the strut tower isn't anything to worry about either, altho if it gets too big then you might want to check your bushings (they might just be called mounts in these cars...).
