Temperature adjustment control does not work
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by ralphEY, Dec 3, 2016.
  1. ralphEY
    ralphEY Junior Member
    NE
    I have a 2012 Prius c . I have always noted the radio to seem to not work on the first touch it always takes two touches to get it to react.. I never thought much about it but now the temperature adjustment gauge is not working, I can turn it and the temperature reading moves up and down but the heat stays at one temp. Every time I start the car no matter where I left the setting when I start the car it says 75. I can put on the ac and still there is air coming out at 75 . I can turn the gauge up and won and it shows temps from low to hi but the only thing that blows out is air at 75
  2. Sean Nelson
    Sean Nelson Active Member
    421
    181
    Vancouver, BC Canada
    Just as a sanity check, is the light on the "auto" button lit up?
  3. ralphEY
    NE
    HI Sean :
    No its not on I have turned it on and off etc. I am thinking of unplugging the 12 v battery and letting the computer reset .
    75 is fine now but once summer comes i will want my ac again
Loading...
