Temporary Flashing check engine light
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Jeff O'Connor, Oct 24, 2018.
  1. Jeff O'Connor
    Jeff O'Connor Junior Member
    Stratford, CT
    Temporary flashing check engine light when starting, blinks maybe six times before engine starts.
    When gas engine kicks in, it turns off. No error code on ODB scanner.... thoughts? help! Thanks all..
  2. edthefox5
    edthefox5 Senior Member
    10,096
    4,837
    Clearwater, Florida
    Only thing I have heard that makes the check engine light turn on and off intermittently is your out of engine oil.
  3. edthefox5
    10,096
    4,837
    Clearwater, Florida
    Which usually damages the engine.
  4. SFO
    SFO Senior Member
    5,302
    4,251
    Northern California
    How many miles does this vehicle currently have?
    What make and model is the OBD2 scanner?
    Raytheeagle likes this.
  5. srellim234
    srellim234 Senior Member
    1,201
    1,694
    Laughlin, Nevada
    Double check which light you're referring to. That is the behavior of the "MAINT REQD" light starting at 4500 miles, letting you know the 5000 mile maintenance is due soon. There are no codes because there is nothing wrong. It should be reset after every 5000 mile service. In 4500 miles it will flash like that again.
    #5 srellim234, Oct 24, 2018
    SFO and Raytheeagle like this.
  6. SFO
    SFO Senior Member
    5,302
    4,251
    Northern California
    ^^^ If it was the "MAINT REQD" light that started flashing at 4500 miles, it will stay in a steady "ON" state once it hits 5k miles.
    srellim234 likes this.
  7. srellim234
    1,201
    1,694
    Laughlin, Nevada
    Yes, it will. The OP gives no indication as to how long it's been flashing so it may not have been flashing for 500 miles yet. Your note about the flashing light becoming a solid light is good information for someone not familiar with how the system works. (y)
    SFO likes this.
  8. Jeff O'Connor
    Stratford, CT
    Sorry all,excuse my lack of deep system knowledge, I'm workin' on it - it surely wasn't blinking for 500 miles...before going solid.
    I brought it in to a Toyota service shop. They hooked it up to the big system to look. They checked it out. No issues. I was asking them on the phone, and they'd say you don't have a "MAINT REQD" light on. I got in the car, started it - "MAINT REQD" light is on. After getting it home, I thought why don't I try to reset it myself?, the darn thing turned off, and hasn't come back.
    Thank You all for you input.
    srellim234 and SFO like this.
  9. bisco
    52,791
    time to change the oil, check the filters and rotate the tires?
