Temporary modification for Tomato Festival
Discussion in 'Gen 2 Prius Accessories & Modifications' started by metal_chair, Jul 7, 2008.
  1. metal_chair
    metal_chair Nashville Prii Unite!
    65
    Nashville
    I'm wanting to turn my 08 Barcelona red into a tomato for a day
    by putting a stem and leaves on top of it to make it look like giant energy efficient tomato! any suggestions?
  2. McDonald
    McDonald New Member
    264
    Boston, MA
    Ha, this is amazing. Be sure to get pictures and to post them!
    Whatever you do, don't put tomato sauce or tomato paste anywhere on your car. It's high acidity may not mesh well with the paint.
    You should hang a bottle of Heinz Ketchup from your rearview, and open the hatch tail gate style and get some fresh tomato salsa and guacamole and chips.
  3. Jack66
    Jack66 Kinda Jovial Member
    766
    Stafford, Virginia
    Stationary tomato or moving tomato? They are slightly different engineering and artistic problems.
  4. Godiva
    Godiva AmeriKan Citizen
    10,339
    Green felt if you can afford it. Put some weight in the stem with a bag of rice, polyseter fiberfill the rest up to the top. Elastic to hook to the sides. I'll assume the windows are open. You could tie it inside, or maybe use upholstery screw pins to pin it to the headliner.
    I'd probably zigzag some florists wire to the leaves to give them a little body, make them "poseable".
    How much time do you have? Do you sew?
  5. metal_chair
    65
    Nashville
    probably stationary
  6. metal_chair
    65
    Nashville
    I think you are on the right track I think I follow your idea, and yes I sew a sewing machine is just a powertool for cloth too bad DeWalt doesnt make a 18v cordless sewing machine.
  7. Jack66
    766
    Stafford, Virginia
    Any pictures? :D
  8. Ichabod
    Ichabod Artist In Residence
    1,790
    Newton, MA
    Use the antenna to help support the stem structure maybe? If you need to open the hatch that might not be the best spot though... on second thought, if the stem gets heavy you don't want to bend your antenna. You probably need some nice insects on there too (as opposed to pests)... maybe a ladybug.
  9. Jack66
    766
    Stafford, Virginia
    Red plastic or tissue paper over the windows since it will be stationary. You can probably get it at a craft store.
  10. metal_chair
    65
    Nashville
    Im collecting materials and ill post some pics
Loading...
