Featured Tesla Cybertruck is here
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by Gokhan, Dec 1, 2023.
  1. bwilson4web
    16,472
    All deference to Prof. Kelly but:
    My ancient understanding is the AC voltage can be higher than the DC because the zero-crossing allows the victim to be 'thrown off' the circuit. In contrast, DC tends to tighten things up leading to a 'slow burn.'
    Also, I am so old that pre-kindergarten, I once had occasion to test the battery of a portable, tube radio. Not having a proper meter, I used the tongue test. Fortunately, I woke up on the bed behind me ... it is good to be lucky!
  2. PriusCamper
    PriusCamper Senior Member
    13,308
    5,379
    Pacific Northwest, USA
    Good thing I got 20 years to learn all that jazz... Of course I've been pruning trees around power lines since the early 90's and I definitely know that once your flesh completes the circuit your muscles freeze up and you can't let go until all the life has been fried out of them.
  3. Leadfoot J. McCoalroller
    8,220
    7,720
    Pennsylvania
    2018 Prius c
    10 units shipped for the year eh?
    Well at least this truck is pretty good at hauling goalposts around.
    I'd hate to see what a shortage looked like...
    AndersOne and PriusCamper like this.
  4. hill
    8,990
    My read was that this was the first 15 - but in any event presuming the same scenario as model X deliveries - the next batch started just a couple days later ..... & production deliveries went up from there, if deliveries follow the same pattern as the X - for whatever that's worth.
    EDIT
    Just watched a YouTube video with one of the Tesla Engineers stating that on the new V4 Tesla chargers? These pigs will charge at 350 KW !!
    LOL - That 800v architecture ... not too shabby.
    #24 hill, Dec 2, 2023
  5. austingreen
    austingreen Senior Member
    13,712
    4,231
    Austin, TX, USA
    Bob in the frequency range of 50hz-60hz that ac power is typically delivered in outlets, AC is much more dangerous than DC. I believe it is more than twice as dangerous. Most mammals are thrown by dc, but ac can cause them to clamp onto the power, and is much more likely to cause a heart attack. At high frequencies AC is safer.
  6. Isaac Zachary
    Isaac Zachary Senior Member
    2,744
    1,457
    Incorrect, sort of:
    AC and DC will both cause you to clamp down and not let go. Getting thrown or not depends on which muscles the current passes through. Generally if you grab it with your hand it will cause all your hand muscles to tense. But since our closing fist muscles are stronger than our letting go muscles we tend to hold on, be it AC or DC.
    If we aren't grabbing onto the source of current (or where it goes out to ground) it can pass through muscles that cause a person (or animal) to jump or jerk away. Like if you touch it with the back of your hand, the tensing would pull your hand and arm away. Again, it doesn't matter if it's AC or DC.
    The problem with 50 to 60Hz AC is it's more likely to throw the heart into confusion and cause cardiac arrest. Desfibrilators use DC to reset the heart. If you have DC go through your heart, it may stop. But when you're disconnected it will be more likely to restart, unlike with AC that may need the person to receive CPR and an AED in order for their heart to start beating again.
    Another problem with both is electrocution, when electricity warms up the flesh to the point it cooks. Again it doesn't matter if it's AC or DC.
    One advantage of AC is if the current passing through the body is also going through an arc. AC is easier for the arc to stop arcing, but DC is more likely to continue arcing.
  7. rjparker
    rjparker Tu Humilde Sirviente
    10,818
    6,791
    Texas Hill Country
    You can hold 5,000 volts and not get shocked. As long as you are not connected to a ground, neutral or a second phase. Just like a bird on uninsulated high voltage power lines.
    Which is the reason bucket trucks are insulated from the boom.
  8. PriusCamper
    13,308
    5,379
    Seems to be an industry trend... Maybe we'll all end like Cuba and will just have to make do with all our old cars for the next 50 years?
    Isaac Zachary likes this.
  9. bwilson4web
    16,472
  10. vvillovv
    vvillovv Senior Member
    4,336
    1,517
    NY
    Here is Professor Kelly referencing the OSHA AC and DC safety limits ( that don't require the need for protective equipment ) along with the document name for fairly easy lookup and verification.
    youtu.be/yGMcQ6JWlBs?t=690
    I hear you, I was told many years ago by a phyicsist. given all the correct conditions ( two wire under the skin connected to a aaa 1.5 volt battery ) could stop a human heart. I never felt a need to test the warning even if being a bit skeptical at the time and not being provided the exact set of conditions to test with anyways. Not that I would have tried testing that even if I was given the exact conditions....
    I've been shocked enough as a kid to have a healthy respect for all things electric, even 12 volt lead acid motorcycle and car batteries and 1.2 volt high drain NiMH cells.
    #30 vvillovv, Dec 3, 2023
    austingreen likes this.
  11. Mr.Vanvandenburg
    1,358
    626
    2020 Prius Prime
    Online review made it sound amazing. He went on about drive by wire steering and how safe it is in aircraft. If it has mechanical backup like present electric steering has here on the ground, ok. Another video they smacked it with a sledge hammer and it didn’t dent the door.
    As for ac power, not a new idea really. I am pretty sure Ford has it in gas and the electric F series. These kind came out many decades ago. Fabco Power.
    #31 Mr.Vanvandenburg, Dec 7, 2023
  12. bisco
    52,653
    yeah, but a generator without an engine is so much better
  13. Mr.Vanvandenburg
    1,358
    626
    2020 Prius Prime
  14. bisco
    52,653
    Just sold my last pickup, that part of life is past
  15. Mr.Vanvandenburg
    1,358
    626
    2020 Prius Prime
    I drove mine today, love it. Manual shift makes you feel young again, except I have a sore foot. I feel I am missing some awareness about life now. Oh well who cares about older folks musings.
  16. bisco
    52,653
    That’s all we have left
  17. bwilson4web
    16,472
    Apparently the medical insurance companies do ... given how they flood TV, cable, YouTube, and Google ads. Personally, I think they practice medicine without a license. Why would I pay money so some remote clerk can deny paying anything for my medical care.
  18. bisco
    52,653
    Everyone cares about your greenbacks :cool:
  19. Mr.Vanvandenburg
    1,358
    626
    2020 Prius Prime
    Look on the sunny side. I notice animals seem to live in the present much more. I don’t think we should call them animals as if we aren’t. So old or new the present is all there is.
