Featured Tesla has been cheating EPA on mpge and range numbers
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by Gokhan, Sep 2, 2022.
  1. Gokhan
    Gokhan Senior Member
    6,715
    2,672
    Paramount CA
    Wrong again—at two fronts.
    First, the plots have more than the rolling resistance and aerodynamic drag. It is everything as Bob said, including the internal drag forces. In the the Prius Prime, you also get significant lubricant (automatic-transmission fluid) drag in the transmission.
    Yes, it is all fluid dynamics, but there are different kinds of flow. The flow within a lubricant is called laminar flow because it is low-speed, and the drag force is proportional to the viscosity and speed to the first power (at least approximately). The aerodynamic drag is caused by high-speed turbulent flow, and it doesn't depend on the viscosity but it's proportional to the square of the speed. From Wikipedia:
    "Drag force is proportional to the velocity for low-speed flow and the squared velocity for high speed flow, where the distinction between low and high speed is measured by the Reynolds number. Even though the ultimate cause of drag is viscous friction, turbulent drag is independent of viscosity."
  2. Gokhan
    6,715
    2,672
    Paramount CA
    This great. So, what is your current tire model and size? Any wheel covers? What wheels did you get?
  3. Trollbait
    12,832
    Edmunds didn't test the Prius Prime on this range test. Let's look at the Toyota they did; the bZ4X FWD.
    Its EPA range is 242 miles, and fuel efficiency is 3.85 miles/kWh.
    The Edmunds results were 227 miles and 3.51.
    Toyota is cheating worse than some of the Tesla models.
    3PriusMike, Zythryn and Isaac Zachary like this.
  4. Isaac Zachary
    Isaac Zachary Senior Member
    2,783
    1,504
    So you're saying rolling resistance is 0 at 80mph. Interesting. Thanks for proving me wrong!
    Constant (Rolling Resistance):
    Exponential (fluid drag):
    Linear (low speed fluid drag):
    Constant plus exponential (rolling resistance and fluid drag):
    Constant plus exonential plus linear (everything):
    #84 Isaac Zachary, Sep 5, 2022
  5. ToyXW
    ToyXW Active Member
    153
    149
    Sacramento
    The formula the EPA uses reflects their best estimation for dynamometer coefficients determined from coast down testing. The formula is significantly different from the physics of real life.
    EPA formula:
    Where:
    FR = total road-load force to be applied at the surface of the roll. The total force is the sum of the individual tractive forces applied at each roll surface.
    i = a counter to indicate a point in time over the driving schedule. For a dynamometer operating at 10-Hz intervals over a 600-second driving schedule, the maximum value of i should be 6,000.
    A = a vehicle-specific constant value representing the vehicle's frictional load in lbf or newtons. See subpart D of this part.
    Gi = instantaneous road grade, in percent. If your duty cycle is not subject to road grade, set this value to 0.
    B = a vehicle-specific coefficient representing load from drag and rolling resistance, which are a function of vehicle speed, in lbf/(mi/hr) or N·s/m. See subpart D of this part.
    v = instantaneous linear speed at the roll surfaces as measured by the dynamometer, in mi/hr or m/s. Let vi−1 = 0 for i = 0.
    C = a vehicle-specific coefficient representing aerodynamic effects, which are a function of vehicle speed squared, in lbf/(mi/hr)2 or N·s2/m2. See subpart D of this part.
    Me = the vehicle's effective mass in lbm or kg, including the effect of rotating axles as specified in § 1066.310(b)(7).
    t = elapsed time in the driving schedule as measured by the dynamometer, in seconds. Let ti−1 = 0 for i = 0.
    M = the measured vehicle mass, in lbm or kg.
    The physics formula for steady state speed on flat ground:
    (a) Aero drag formula: 0.5 * rho * V^2 * Cd * A
    (b) Rolling resistance formula: Crr * Weight * Gravitational acceleration
    Weight affects rolling resistance, but the EPA formula divorces the rolling resistance coefficient from weight. In fact, on a grade of 0, weight makes no difference whatsoever to the EPA formula sin(atan(0)) = zero. Instead, the EPA adds a 3rd coefficient - a constant force which would be present at any speed. It is bizarre, but I presume SAE has a good reason for it.
    The EPA coefficients vary significantly between the same model of car. Tesla also has a number of Model3 variants with a negative rolling resistance coefficient which, again, seems divorced from reality. These are for 2019:
    Using the EPA formula and those coefficients, I get the following graph:
    Gokhan, Zythryn and Isaac Zachary like this.
  6. Gokhan
    6,715
    2,672
    Paramount CA
    What are you talking about? I never said that. What I said was
    F = R + bv + cv^2,
    with R being the rolling resistance, b being a coefficient for laminar-flow hydrodynamic (ATF) drag, and c being a coefficient for turbulent-flow aerodynamic drag.
  7. Gokhan
    6,715
    2,672
    Paramount CA
    LOL Couldn't you choose different colors for the curves in your plot, as it's impossible to tell which is which? Great work though!
    So, my conclusion was correct! Prius Prime has a lower aerodynamic-drag (turbulent-flow) coefficient c (quadratic in v) than Model 3, but it has a higher hydrodynamic-drag (laminar-flow) coefficient b (linear in v) than Model 3 if you model the total drag force as in my formula below. This linear-in-v laminar-flow hydrodynamic drag is probably being caused by the ATF in the Prius Prime transmission.
    F = R + bv + cv^2
    Note that in my formula the rolling resistance is a constant I called R.
    Nevertheless, as I said before, CdA (drag coefficient times the area) of Prius Prime and Model 3 are extremely similar, Prius Prime being slightly lower or higher depending on the particular Model 3 year and trim.
    I wouldn't call b the rolling-resistance coefficient. It's a hydrodynamic-drag coefficient. SAE should have definitely included a constant term in their fit. You're right that the rolling resistance is fairly constant at low to moderate speeds, only depending on the tire model and size and vehicle weight. It only stars to vary when the tire approaches its speed limit.
    Calculating rolling resistance with a parametrical equation
  8. fuzzy1
    10,721
    To pick a nit ...
    Just about everything I'm seeing shows fluid drag as a polynomial, specifically a quadratic equation, not an exponential function.
    Remember that polynomials are simple power functions, where the exponents are fixed integers. These are not exponential functions. 'Exponential' means that the exponent itself is the variable, not fixed.
    #88 fuzzy1, Sep 5, 2022
    Isaac Zachary likes this.
  9. Isaac Zachary
    2,783
    1,504
    (y)
    I'm admittedly so so at math but less than great with English.
  10. john1701a
    john1701a Prius Guru
    12,840
    5,312
    58
    That was just your driving conditions, something with cruise? Sorry, I forgot what was different.
    Neither my wife or I ever have that happen. Both Primes remain in EV until temperatures drop below the heat-pump threshold.
  11. Gokhan
    6,715
    2,672
    Paramount CA
    One interesting thing I noticed is when you compare Prius Prime to vanilla Prius.
    Prius Prime has a smaller aerodynamic-drag coefficient c than Prius, but it has a larger hydrodynamic-drag coefficient b.
    Looking at the new-car features manuals, they both use the P610 transaxle. However, Prius Prime has different number of teeth on the final drive and driven gears, with the total speed-reduction ratio for Prius Prime and Prius being 3.218 and 2.834, respectively. Could subtle differences explain the different hydrodynamic-drag coefficients b for Prius Prime and Prius or there is some other factor? I don't know. Of course, Prius Prime is a heavier car than Prius, and perhaps the coefficient is larger for Prius Prime because SAE omits the constant term that would normally represent the rolling resistance, which is absorbed into this linear b term. So, the b term could simply differ because of the rolling resistance.
    Nevertheless, I also seem to be right in that Prius Prime has a lower aerodynamic drag than Prius. I also showed the EPA highway mpg numbers as evidence for that, but the EPA numbers can somewhat vary according to the tester even for ICE cars, which was the topic of the original post. If the EPA numbers are accurate, Prius Prime has certainly less aerodynamic drag than Prius.
  12. Gokhan
    6,715
    2,672
    Paramount CA
    When you turn on the defogger, Prius Prime tends to turn on the ICE even in the EV mode. Perhaps Bob is talking about that.
  13. john1701a
    12,840
    5,312
    58
    Here's an interesting (and somewhat naïve) question that popped into mind of based on the variety of other factors of influence mentioned... how exactly is the aerodynamic nature of the vehicle actually measured? Is that coefficient reflective of the entire vehicle or the surface area of the body above the frame? It other words, does the underside come into play? When you raise a vehicle, the body doesn't change at all, yet the aerodynamic penalty increases.
  14. Isaac Zachary
    2,783
    1,504
    The coefficient and cross sectional area mean that if you made the car bigger and doubled its cross sectional area but kept the exact same shape the air drag would also double.
  15. Gokhan
    6,715
    2,672
    Paramount CA
    Good question. The answer is nontrivial. Obviously, the car needs to be actually driven as opposed to putting it on a dynamometer and some actual driving data needs to be collected to actually measure the aerodynamic drag force. This is explained in detail here:
    https://ww2.arb.ca.gov/sites/default/files/2020-04/13_313_ac.pdf
  16. ToyXW
    ToyXW Active Member
    153
    149
    Sacramento
    Yeah, I started with different colors but it became too difficult to keep things straight so for that graph I just made all the Prii blue and all the model 3s green. From it, you could see that the model 3's drag was mostly in line with the various Prius variants - significantly higher than the prius at low speed, but trending lower than most prius variants as speeds increased.
    Here is the graph with just the Prius variants. The prime model is pretty much in the middle:
    bwilson4web and Gokhan like this.
  17. Gokhan
    6,715
    2,672
    Paramount CA
    Note that what is relevant is the "target coefficients," not the set coefficients.
    Target coefficients are actually measured on a test track, not on a dynamometer. They represent the actual total drag force F on the car, and the equation is
    F = A + Bv + Cv²,
    which is a simple quadratic equation.
    Set coefficients are irrelevant for our purpose. They are used to set the dynamometer so that the tire rolling resistance and internal drag forces are not double-counted. If you simply used the target coefficients to set the dynamometer, these forces would have been included twice. What they do is to set the target coefficients first and then let the vehicle coast down in neutral. Then the tire and internal drag subtracts from the target drag and can be measured from the acceleration of the dynamometer. Once it is known, the set coefficients to subtract it are calculated, and the dynamometer is reset using these set coefficients so that they don't double-count the tire and internal drag.
    These are the target coefficient A, B, and C values, which model the actual tire rolling resistance, internal drag, and aerodynamic drag in the quadratic model, the lower the better, from best to worst:
    Year Make Model A (tire-rolling-resistance coefficient) B (internal-drag coefficient) C (aerodynamic-drag coefficient)
    1 2022 Toyota Prius Prime 18.816 0.38689 0.012501
    2 2022 Toyota Prius 18.272 0.29545 0.013793
    3 2022 Toyota Prius Eco 17.130 0.28731 0.013857
    4 2022 Tesla Model 3 RWD 37.170 0.04700 0.014400
    5 2022 Tesla Model 3 LR AWD 34.980 0.08650 0.014800
    6 2022 Toyota Prius AWD 25.590 15.868 0.015074
    7 2022 Tesla Model 3 Performance AWD 49.010 −0.20010 0.020000
    So, Prius Prime is the absolute winner in aerodynamic drag here, readily beating Prius and any Tesla Model 3.
    Source: Data on cars used for testing fuel economy | US EPA
    This is the resulting actual total drag force F for 2022 Toyota Prius Prime (133 mpge) vs. 2022 Tesla Model 3 RWD (132 mpge).
    To clarify the confusion by some earlier on why the two curves come very close around 90 mph and then start to slowly separate again: Prius Prime has a very large internal-drag force—the Bv termin the quadratic model, which becomes more pronounced when the vehicle speed increases. However, eventually the aerodynamic-drag force—the Cv² term—wins and the two curves start to separate again.
    Note that later the vehicle weight additionally factors in fuel economy after the dynamometer tests with the EPA drive cycles are done, along with this total drag force that was measured coasting down on field track.
    This addresses the point in the original post that the EPA EV fuel efficiency of Model 3 is greatly exaggerated over that of Prius Prime—by 27% according to my previous rough calculations.
    #97 Gokhan, Sep 6, 2022
  18. Trollbait
    12,832
    After all this, the 2020 Model 3 SR+ is still rated 141mpge, and the Edmunds test proves it is correct.
    The only 'nefarious' thing the Prius Prime to Model 3 comparison might prove is that Toyota wasn't honest with the rating.
  19. bwilson4web
    16,549
    Thank you!
    I’ve often felt alone about using roll down coefficients for comparing drag force or calculate HP/kWh as a function of speed.
    BTW, I am getting two new tires for the rear drive wheels only to discover Bridgestone no longer makes the ECOPIA series.
    So I ran some benchmarks on the old tires at 35, 55, and 70 mph over 10 miles each way between 1:30 AM and 3:30. No wind, humid with patches of fog, at 71 F. Will share after confirming the quadratic formula:
    The updated, quadratic.
    #99 bwilson4web, Sep 6, 2022
    Gokhan likes this.
  20. farmecologist
    farmecologist Senior Member
    1,960
    1,801
    Southern MN
    Good work here folks...I love posts like this that use real data. (y)
    So what is the current consensus here given the recent discussion? Did Tesla overstate their MPGe claims or not?
    Gokhan likes this.
