Featured Tesla has been cheating EPA on mpge and range numbers
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by Gokhan, Sep 2, 2022.
  1. Tideland Prius
    16,683
    Actually I believe it’s off my 0.01. Cd 0.24 for Prius vs. 0.25 for Prime. The dual wave rear window wasn’t able to completely offset the front end design.
    austingreen likes this.
  2. Gokhan
    Gokhan Senior Member
    6,718
    2,672
    Paramount CA
    From what I understand, the equation with the set coefficients represents the aerodynamic-drag force as a function of speed. Basically, if you subtract the set equation from the target equation, you get the tire rolling resistance plus driveline drag. So, what does a negative aerodynamic-drag force indicate? No, it doesn't indicate the violation of the second law of thermodynamics. It indicates a tailwind. Now, that's cheating. ;);)
    Speaking of headwinds and tailwinds, OEMs are required to do the field-track coast-down in both directions to minimize that effect.
  3. Gokhan
    6,718
    2,672
    Paramount CA
    More thoughts on the target vs. set coefficients:
    As I said, the goal of the set coefficients is to simulate only the aerodynamic drag on the dyno. However, it has the assumption of the tire rolling resistance being the same on the dyno as on the field track, which is obviously wrong. The road surface is not made of steel.
    To make things more meaningful, I plotted an equation with "modified" set coefficients by simply setting the set coefficient A = 0. The modified set-coefficient plot should be close to the actual aerodynamic-drag force. So, Model 3 wins. Among the Prius models, Prius Prime wins in having the least aerodynamic drag.
  4. ToyXW
    ToyXW Active Member
    153
    149
    Sacramento
    None of the aerodynamic "C" coefficients were negative so no tailwinds. But 3 out of the 4 Tesla Model3's had a negative driveline "B" coefficient which, to me, suggests Tesla's "neutral" may be providing a little bit of power. If I were an EPA tester I'd either unplug the traction battery or compare the change in the neutral coast state of charge against the change in an idle state of charge for an equivalent amount of time.
    You might plausibly use a little more processing power with stability control & antilock braking systems when coasting vs when parked, but to legitimately achieve those coefficients suggest some extra power going to the wheels...
  5. austingreen
    austingreen Senior Member
    13,714
    4,232
    Austin, TX, USA
    from the numbers the Tesla has a slightly bigger frontal area while having a lower cd than the prime giving it a slight 5% advantage in cdA or drag, but this is only important at highway speeds or more. The Tesla also likely is more electrically efficient at high speed. Car and driver has confirmed that both rolling resistance and aerodynamic drag for tesla's are within margin for error of their test so no cheating but there could be rounding. yes wider stickier tires on the Tesla will cause higher rolling resistance, but as speed increases this is less of a factor as it is constant for distance while drag is proportional to the square of velocity. MPGe is based on power from the plug, and I trust Tesla is likely more efficient on the highway and the prime more efficient in the city. That is a good thing as Tesla is tuned toward highway milage for range while city mpge is also great. The Prius prime is going to primarily use gasoline on long highway trips while the batter will be used mainly in the city and just for short highway trips.
    That goes to the epa's mpge. The guessometer in the Prius prime tellying you what mpge is, is likely not accurate. I really like my Tesla. My girlfriend in spite of her hatred of Elon muak (and we ended up in a bar with him after he moved here) loves my Tesla. she was mad at me for talking to him nicely. ;)
    Gokhan and Zythryn like this.
  6. Gokhan
    6,718
    2,672
    Paramount CA
    Oh, no, these are the physical meanings of the target and set coefficients:
    • Target coefficients: measured total field-track drag force (including field-track rolling resistance, driveline drag, and aerodynamic drag)
    • Set coefficients: estimated aerodynamic-drag force + measured field-track rolling resistance − estimated dynamometer rolling resistance
    F = A + Bv + Cv²
    F is the drag force. A is mostly the tire rolling resistance and some static driveline friction, B is mostly the driveline drag, and C is mostly the aerodynamic drag and some driveline drag, but this is only a quadratic model and not an exact science; therefore, the coefficients A, B, and C get mixed.
    Here are my observations:
    1. From the target (total) drag and set (aerodynamic) drag plots I made above (use the modified set plot where the curves go to 0 at 0), Model 3 appears to have quite less aerodynamic drag but quite more driveline drag, perhaps thanks to its performance drivetrain in comparison to Prius Prime's economy drivetrain.
    2. The net result is that Prius Prime still has less drag at all speeds, even when v → ∞. It is also interesting that the driveline drag has both a linear and a quadratic component. In fact, Model 3's driveline drag is mostly quadratic.
    3. The small negative B in the Model 3 set coefficients is a result of the quadratic fit. Remember that the set coefficients represent the aerodynamic drag only (plus the track-minus-roller rolling-resistance correction). It could be a part of the rolling-resistance correction or a part of the aerodynamic drag.
    4. Another interesting observation is that Model 3's tires have more rolling resistance on the steel rollers of the dynamometer than on the field track, as evidenced by a negative set coefficient A, which is unusual.
    #126 Gokhan, Sep 7, 2022
  7. Lee Jay
    Lee Jay Senior Member
    5,850
    4,036
    Westminster, Colorado
    I did this experiment myself. LRR tires reduced rolling friction on the same car at the same temperature and tire pressure by about 40%.
  8. 3PriusMike
    3,101
    2,421
    Silicon Valley
    40% seems plausible but on the high end. Tests have shown that a 10% decrease in friction gives about 1 or 1.5% improvement in mpg.
    Multiple other tests have shown that mpg improvements can vary by about 1.5 to 4.5%
    https://en.wikipedia.org/wiki/Low_rolling_resistance_tire
    Mike
    Isaac Zachary likes this.
  9. Lee Jay
    5,850
    4,036
    Those tests must be either wrong or all high-speed.
    Over the average US car's lifetime, about 2/3rds of the propultion energy is lost to rolling friction and 1/3rd to aero losses. That's because we spend a lot of time and miles in city traffic. My average speed over the last 5 and a half years is 28mph.
  10. 3PriusMike
    3,101
    2,421
    Silicon Valley
    You should edit the wikipedia page with links to better studies
    Mike
  11. Lee Jay
    5,850
    4,036
    The article is wrong because of a misinterpretation of the reference it uses.
    The article says, "...as approximately 5–15% of the fuel consumed by a typical gas car may be used to overcome rolling resistance.[1]"
    This is a screenshot from that reference:
    The problem is whoever wrote the article got confused between fuel consumed and energy consumed by motion.
  12. mikefocke
    4,083
    1,865
    Sanford, NC
    I'm not surprised at that figure. Went in for my fifth Covid shot today and on the way back I enabled the info eco screen and it showed 23 MPH and much of the trip was at 55. But then there was the slow stuff in the neighborhood and the stop lights at the end and the slow in the parking lot to lower the average.
  13. austingreen
    13,714
    4,232
    Austin, TX, USA
    Those numbers are likely correct for gasoline cars without regen braking, but in EVs the drive train is much more efficient and braking, making aerodynamics and rolling resistance more important.
    https://www.nhtsa.gov/DOT/NHTSA/NVS/Vehicle%20Research%20&%20Test%20Center%20%28VRTC%29/ca/Tires/811154.pdf
    Here the example has 4.2% of fuel going to rolling resistance, 2.6% to drag, 5.8% to braking.
    https://www.fueleconomy.gov/feg/atv-ev.shtml
    because there is less loss in charging and the motor, and regen recoups much of the braking energy, the example gives 25% of energy in rolling resistance and 39% as drag, 25% is dissipated as braking, but 22% of that is regen and reused. YMMV!
  14. Isaac Zachary
    Isaac Zachary Senior Member
    2,787
    1,506
    If the relation is 4.2% to rolling resistance and only 2.6% to drag and 5.8% to braking, where'd the other 87.4% go to?
  15. austingreen
    13,714
    4,232
    Austin, TX, USA
    Its in that paper, and this was conducted on a non hybrid gasoline car. The bulk goes to engine inefficiency including idling (that part is much better in a hybrid) then their are driveline losses - that is 85% of the gasoline. In a Prius this may be around 70% instead. Then they gave 2.4% to accessories like AC, power steering, etc.
  16. Zythryn
    Zythryn Senior Member
    6,412
    4,415
    You know… the primary purpose of an ICE car… heat! :LOL::LOL::ROFLMAO:
    3PriusMike likes this.
  17. Isaac Zachary
    2,787
    1,506
    If only mine would heat up. It's been freezing cold these past few mornings! Today I went and bought a 1,500W block heater. That ought to do it!
  18. Zythryn
    6,412
    4,415
    Interesting point, which hadn’t occurred to me before.
    ICE vehicles put out >50% of their fuel’s energy as heat. Why isn’t all that heat available more quickly?
    I’m guessing all that heat initially goes into heating the engine block?
  19. Isaac Zachary
    2,787
    1,506
    Complete thread derailment here, but on the one hand the problem with ICE's is the heat is mostly available after a person reaches their destination. The problem with using the heater is the engine then takes longer to warm up, and is even more likely to not reach ideal temperatures by the time one gets to their place of work (or wherever).
    On the other hand, I've had the crazy idea to add some sort of heat tank to the car to store some of the hot coolant before the radiator even gets used. Then, getting home, have some way of transferring that heat to heat storage at the house for making hot water or home heating or something else that's useful instead of just dissipating it into the atmosphere.
    The inverse idea is to have a stationary natural gas generator (natural gas is cheaper per thermal unit than electricity) and use that electricity for charging an EV and the exhaust and engine cooling for heating the home or hot water.
    The reality, though, is my place of work is too close. It's just not far enough for the car to warm up properly on the road, even in summer. But when it's already 0°C when I go to work at 4:00AM, it's not very comfortable to walk or ride a bike that far. I do miss our Leaf for driving nice and toasty to work when it's -40°F/-40°C outside.
  20. Trollbait
    12,832
    A couple gallons of hot coolant isn't going to do much for heat use at home, and water is heavy to be adding more to the car.
    The gen2 Prius had thermos it pumped hot coolant into after shut down to help with the next warm up cycle. The temperature gauge was noticeably lower on Monday mornings after sitting for a week end.
    There are 'tiny', home sized cogen generators for supplying power, and using the waste heat. For a larger building, Honda has a natural gas one available in Japan that is a true Atkinson cycle engine.
