Tesla Model 3 Wheel Swap
Discussion in 'Gen 5 Prius Accessories and Modifications' started by Xov’ze, Nov 7, 2023.
  1. Danno5060
    Danno5060 Active Member
    395
    202
    Wyoming
    Would it also be possible to go to the LE's 17" wheels and tires?
    PandaBOT likes this.
  2. PandaBOT
    PandaBOT New Member
    Colorado
    2023 Prius
    XLE AWD-e
    Has anyone tried the 195/60R17 from the LE on the AWD XLE? I just blew a tire today and the wait time for a new one is about 30 days! I asked the dealership about doing this switch, but they don't have any experience with the new Prius and don't know if it'll clear the brake calipers. I've read through a ton of these posts and TBH, I'm still a bit confused about what will work and what won't work.
  3. YELLOW PRIUS KOREA
    YELLOW PRIUS KOREA New Member
    KOREA
    2024 Prius
    It's Hubspace!
    I think 215/50R18 would be fine too!
    There are so many different options..
  4. Danno5060
    395
    202
    Wyoming
    I tried looking up the parts on Lakeland Toyota's website (Authentic Toyota Parts | Toyota Parts Overstock (lakelandtoyota.com)). It looks like the 17" wheel (P/N 42611-47651, there's also a 42611-47701. I don't know what the difference is), and according to their fitment guide these fit all of the 2023 Prius models.
    You may want to look up things like the dust covers, calipers, caliper brackets, disks... too. Those wheels are $390 each, which I'm imagining will take Toyota a while to get to you as well. Those seem to be common between a few models of Prius and Corolla. It would take quite a bit of research to see what's compatible with what and build a matrix of what cars you could look at. I doubt if the Toyota dealer is going to be that much help, but it might also lead you to some compatible salvage parts (say from a 2020 Prime, which would get you a 15" wheel).
    The big reason I suggest the 17" tires (and wheels) from the 2023 LE would be that the wheel offset, and outside diameter are the same. I had a bad experience with my first car, installing aftermarket wheels. The offset wasn't quite compatible with the car, and every speed bump I hit would scrape the sidewall on the wheel well. If Toyota has a Prius wheel that fits, that's what I'd go with.
    Just to be thorough here, (and hoping not insulting), this would require you to buy the 17" wheels as well as the tires because you can't put a 17" tire on a 19" wheel.
  5. darkstar3274
    darkstar3274 Junior Member
    46
    2022 Prius Prime
    Hello Xov'ze how are things longer term with those Tesla wheels and tires? Any detriment to mpg or any driving issues? Thanks!
  6. Xov’ze
    Xov’ze Member
    43
    46
    2023 Prius
    No issues to report! It’s a little hard to say what the effect of the wheels were on mpg because I’ve done a few other mods (TRD front spoiler, custom side skirts, bc racing coilovers), but I’m pretty sure the wheels had a completely negligible effect overall.
    purplePriii and darkstar3274 like this.
  7. darkstar3274
    46
    2022 Prius Prime
    Thanks Xov'ze!
  8. darkstar3274
    46
    2022 Prius Prime
    Which lug nuts did you use? Like these in the attached picture? Thanks.
  9. Xov’ze
    Xov’ze Member
    43
    46
    2023 Prius
    Those look to be the same dimensions as the lugs I’m using.
    I’m not an expert, so do this at your own risk ofc, but the biggest concern for me choosing lugs was finding a set of M12x1.5 that had a wide enough seat for the tesla wheels. .9” (23mm) max diameter has worked out okay for me, but only because I haven’t found anything larger for the thread size.
    darkstar3274 likes this.
  10. darkstar3274
    46
    2022 Prius Prime
    If the conical mating area of the replacement lug nuts are same as that of the OEM i.e fit into the wheel holes fully not partially and threaded length engagement of the new lugs with the bolts are same then should be good right? Is is just the blue area interfacing or also the area marked with red? Additionally, with regards to the curb weight, the Prius 5th gen is around 300lb lighter overall than the Model 3 comparing heaviest Prius version with lightest Model 3. Acknowlege it isn't that simple but just my thoughts. Thanks.
    #30 darkstar3274, Sep 29, 2024
  11. Xov’ze
    Xov’ze Member
    43
    46
    2023 Prius
    Only the blue area interfaces, but the bolt holes in the tesla wheels are wider to accommodate the oem M14x1.5 bolts/nuts, so the central part of the M12x1.5 bolts sits inside the hole instead of mating with the conical surface. With a .9” max diameter, only the outer half of the mating surface makes contact with the wheel. I haven’t had a lug fail on me yet, but it’s definitely not an ideal setup
    When I get off of work I’ll take a picture of the wear on the nuts so you can see.
  12. darkstar3274
    46
    2022 Prius Prime
    Thanks so much!
  13. darkstar3274
    46
    2022 Prius Prime
    Xov'ze I may have found your answer (unless you are aware of these boards already)
    https://www.civicx.com/forum/threads/tesla-wheels-fit.45740/
    and especially this one...
    Tesla Model 3 Aero wheels installed | Acura TSX Forum
    I did get a set of the aero wheels with tires and covers for a super low price. Have ordered these from Amazon
    (not sure if they need to be open ended)
    J2 Lug Nuts 20 Pcs Set (Aluminum, Black, Close End Acorn Tuner, M12 x 1.50, 25MM Diameter/35MM Height)+Adapter
    Incidentally the 2025 Camry SE has 235/45R18 tires as well albeit on an 8 inch rim.
    #33 darkstar3274, Oct 10, 2024
    Xov’ze likes this.
  14. Xov’ze
    Xov’ze Member
    43
    46
    2023 Prius
    this is literally perfect thank you so much??
  15. darkstar3274
    46
    2022 Prius Prime
    Did you get the wider lug nuts? I have not yet done the swap although I have everything ready to go (did a swap to the 17" stock wheels in the meantime)
  16. Xov’ze
    Xov’ze Member
    43
    46
    2023 Prius
    I did in fact! They have a noticeably wider mating surface than the other lugs I was using, definitely much better for my peace of mind
    I did also get a set of hub-centric rings, though I’m unsure how much they’re actually doing considering the conical lug seats probably center the wheels just fine. A set is dirt cheap, so better safe than sorry ‍♀️
  17. xliderider
    xliderider Senior Member
    8,140
    3,277
    Honolulu, HI
    It's always advisable to use hubcentric rings to ensure that the wheel is perfectly centered on the hub.
    SM-G781V ?
  18. Mendel Leisk
    42,100
    I've got a set of Tesla 3 rims/tires in the garage right now, and I've learned quick, with the 235/4R18 stock tire size, you've got to lay them down or stack the them very carefully; the rubber and the rim both make contact at about the same time.
    Xov’ze likes this.
  19. xliderider
    8,140
    3,277
    Honolulu, HI
    I have two of these racks in my garage, they work really well at storing wheels and rims out of the way.
    MaxxHaul 70489 Adjustable Wall Mount Folding Tire Storage Adjust From 32 to 48 inches Wide Up To 300 lbs Capacity. https://a.co/d/g0DUO6P 20221208_100348.jpg 20210309_120848.jpg
    SM-G781V ?
  20. Makamogo
    Makamogo New Member
    SoCal
    2024 Prius
    Thanks for the inspiration! Which lug nuts and hubcentric rings did you buy?
