Tesla Model 3 Wheel Swap
Discussion in 'Gen 5 Prius Accessories and Modifications' started by Xov’ze, Nov 7, 2023.
  1. Xov’ze
    Xov’ze Member
    43
    46
    2023 Prius
    pretty sure these are the lugs I’m using, I got open-ended ones because I’m currently running a set of haloblk aero disks that bolt onto the lugs, pretty sure the closed end variety will work just fine
    as for the hub-centric rings just make sure you’re getting 60.1 mm inner diameter to 64.1 mm outer diameter. I’m personally using a metal set but there’s a bunch of different options on amazon
    Makamogo likes this.
  2. Makamogo
    Makamogo New Member
    SoCal
    2024 Prius
    Thanks! I'm not sure if there was a link or a photo in your message about the lugs, but it didn't seem to come through.
  3. Mendel Leisk
    42,345
    The site doesn’t display directly posted Amazon links, though if @Xov’ze comes back and embeds the link in a text string it will work: you need to click this icon:
    and paste the Amazon link. It’ll post the text string with a blue tint, acting as a hyper link.
    that said, also check with a dealership parts department. When I got snows for our ‘10, dealership sold me Corolla steel rims ($70 CDN apiece) and Toyota spec open-ended, rough-finish lug nuts (20 for $31 CDN). Also supplied, mounted and installed with snow tires.
    in your case there might be another compatible compatible Toyota rim and lug nut. The rim likely won’t need hub adapter ring either.
  4. Xov’ze
    Xov’ze Member
    43
    46
    2023 Prius
    Whoops! Thought the link not showing up was an issue on my end
    The link
    Makamogo and Mendel Leisk like this.
  5. Makamogo
    Makamogo New Member
    SoCal
    2024 Prius
    Thanks Mendel!!
    Thank you!!!
    #45 Makamogo, Dec 8, 2024
