Featured Tesla quality
Discussion in 'Tesla' started by Lee Jay, Feb 3, 2020.
  1. orenji
    orenji Senior Member
    5,887
    3,489
    How many Mira have caught fire?? How many Tesla?
  2. orenji
    5,887
    3,489
    Hydrogen is lighter than air. It dissipates instantly and is much safer than gasoline.
  3. orenji
    5,887
    3,489
    There is no way to screw up, the pumps and cars talk to each other via infrared technology. If there is an issue the car and pump know before you do.
  4. bwilson4web
    16,537
    <AHEM>Tesla doesn't have to announce a recall. The anti-Tesla crowd does it for them.
    hill likes this.
  5. orenji
    5,887
    3,489
    (n)
  6. Trollbait
    12,831
    I was thinking about what happens if the hydrogen in the tank gets above 100C. Part of the high cost for hydrogen stations is in preventing that while also providing a quick refueling without special training.
    Working with anything at those pressures has degree of risk higher than with a liquid.
    Which was my point is saying you can't compare refueling with gas to refueling with a liquid. It took far more work and money to make refueling with hydrogen easy and safe, than it did to make auto shut off gas pumps.
    How far along do you think ICE cars be if they had to wait for the auto-shut off pumps before selling cars?
  7. orenji
    5,887
    3,489
    Auto shut off pump still can fail and spill gas everywhere. All fueling stations and chargers should be a safe as can be. Money well spent if you ask me.
  8. t_newt
    t_newt Active Member
    218
    247
    The 'lighter than air' and 'dissipates instantly' are not good qualities in an enclosed space, like a garage without ventilation in the ceiling. Here's a NIST video for an example.
    I've always wondered what would happen if there was a hydrogen leak in an underground garage, like at a shopping mall or in a city garage. How the heck do you clear out the invisible, odorless gas while avoiding a dangerous explosion? That's if you even realize the hydrogen is there in the first place. And if the hydrogen somehow burns without exploding, the flames are nearly invisible.
  9. orenji
    5,887
    3,489
    Sensor will warn you and since it dissipates it not a real concern with a Hydrogen vehicle.
  10. El Dobro
    El Dobro A Member
    7,106
    3,282
    Haven't had an electricity spill yet.
  11. Zythryn
    Zythryn Senior Member
    6,412
    4,414
    We did have a solar spill yesterday. Otherwise known as a nice, sunny day ;)
  12. orenji
    5,887
    3,489
    A Tesla Supercharger at a Wawa store in Parsippany, New Jersey, ignited into flames.
  13. El Dobro
    El Dobro A Member
    7,106
    3,282
    Sounds more like a problem with the mechanics of the station, rather than an electricity spill. ;)
  14. orenji
    5,887
    3,489
    Its still shocking!
  15. hill
    9,039
    I used one years ago that was seriously vandalized at a supercharger station & it still worked. LoL
    So much for danger.
  16. Zythryn
    6,412
    4,414
    iplug and Trollbait like this.
  17. hill
    9,039
    If Mirai catches fire &/or explodes - it doesn't affect others from refueling .... in fact it might actually help refueling, because it's that less likely the main compressed cylinder users fuel from - may still be charged up. Otherwise you might have to wait ½hr or more while the compressor recompress - so the station has the necessary 10K PSI.
    If a station becomes inop, & they sometimes do, how many miles will someone have to drive to the next station. 5 miles? Lits More? All the more reason to knock a few miles off of your actual destination, to provide for such emergencies. Electric car refueling is way more ubiquitous because the electricity is pretty much everywhere people are.
    #177 hill, Oct 8, 2020
  18. Trollbait
    12,831
    If the safety features fail on a hydrogen pump, the risk isn't just a leak or fire. It is the large tanks containing 10k psi going boom. A nonflammable gas at those pressures makes a very effective bomb.
    You are being naive.
    Hydrogen has one of the largest ranges of concentrations with air and be explosive. If it leaks in a home garage, operating a garage opener can be enough spark to ignite it.
    "It readily dissipates" didn't save the Hindenburg, nor the other, some deadier, zeppilins. Nor did it prevent any of the numerous hydrogen explosions at facilities.
    And a hydrogen station in Norway had an explosion.
    Many car fires start from faults in the 12 volt system. Are hydrogen cars equipped with sensors and fire suppression systems?
  19. orenji
    5,887
    3,489
    Scary that it is still able to function with that much damage. Should have a cut off switch when it’s damaged to that extent.
  20. orenji
    5,887
    3,489
