Test drove and the car smells really bad
Discussion in 'Gen 2 Prius Main Forum' started by bigtal, Feb 2, 2006.
  1. RobertL
    RobertL New Member
    Columbus, Ohio
    We bought our Prius New in Oct. 2005. It only had 7 miles on it. I didn't notice any unusual smell. It had the New car smell. Nothing different. I could understand if there was a New glue smell or something like that. But I wouldn't think it would be that strong of a smell. Or that it would last that long. With 1000 miles, more or less I would think the New glue smell or any other unusual smells would dissipate after that amount of time. We currently have about 1800 miles on our Prius and we can still smell the New car smell and that is about it. I would be concerned if there are any unusual smells. I would do what you have suggested and try others out.
  2. Tideland Prius
    16,683
    Maybe it's a 2006 thing?
  3. hobbit
    hobbit Senior Member
    4,089
    470
    Bahstahn
    I posted about this a while ago, and nobody really responded:
    http://priuschat.com/index.php?showtopic=13156
    You are most likely smelling the hybrid battery. My car wasn't
    100% new when I got it but still had new-car smell [possibly some
    from whatever the dealers did to clean up inside a little, but I
    *insisted* that they go nowhere near it with that armor-all goop!]
    and that smell gradually segued into a slightly sharper, more
    plastic-y or chemical smell and finally I realized that yes, it
    is indeed strongest back around the battery vent. I still smell it
    and it's strongest just after cranking a lot of current in or out
    of the battery. Consensus over in the techie group was that it's
    possibly the plastic cell housings getting warm and outgassing a
    little, as opposed to leaking electrolyte ... but I think one spring
    project this year will be to open up the pack enough to look for
    corrosion and clean things up if needed.
    So if those noticing these smells could crawl around the car a bit
    and sniff and try to localize it, that would lead to a good FAQ
    entry if it all eventually points to [hopefully harmless] battery
    odor [aka B.O., so whoever suggested that was, um, almost right]
    _H*
  4. johnnieliu
    johnnieliu New Member
    60
    PNW
    Our 06 also has an order both inside and out. Our 04 RX330 that we bought new did not have the ouside order like what we're experiencing on our Prius. The outside order is definately NOT your typical new car odor, but still "plastic" smelling.
  5. Schmika
    Schmika New Member
    1,617
    Xenia, OH
    How about Bigtal has a more sensitive nose and cannot take it...so he/she should not buy it.
    Other than the "new" car smell I would expect (and it is either gone or I have become used to it) the car is like any other new car.
    Big, did you really expect us to know what you smelled. Smell is very subjective (as in my f*rts never stink)
  6. richard schumacher
    7,686
    1,068
    United States
    Bigtal, takes hobbit's hint: sniff the traction battery vent on the right side of the passenger seat. If the smell is worst there then I would suspect an electrical problem, which the dealer ought to be able to find and fix. The odor of new electrical components should have largely dissipated before 1500 miles.
  7. naterprius
    naterprius Senior Member
    1,843
    Wow. There is nobody more sensitive to objectionable smells than me, and I have noticed nothing in my 2004 Prius, even with the battery cooling fan running. I have yet to sit a 2006, though.
    Nate
  8. Lyn Never
    Lyn Never New Member
    Fort Worth TX
    I picked up my 06 last weekend and the plastic/chemical smell is especially strong when the car has been sitting in the sun for a while. I think it's probably a combination of mysterious coatings, upholstery protectant, new plastic, etc.
    My husband's xB is over a year old and still smells faintly of new car, but it never smelled as chemical as the Prius does.
  9. bigtal
    bigtal New Member
    See I am not crazy :D I think there is something new in the 06 that gives it a strong chemical smell. It is not the standard "new car" smell.
    I think Toyota should consider using different chemicals or going back to what they used in 04 as I haven't seen anybody with an 04 compain about a chemical smell.
  10. Liam
    Liam New Member
    96
    Maybe this is a clue.
  11. bigtal
    bigtal New Member
    Ok, i just came back from the Toyota dealer. They got in a new 06 and called me to take a look at it. I must say that i did NOT smell the same chemical smell, it only had the standard "new car" smell.
    I am now wondering if that smell comes with time? Does anybody have an 06 Prius that is noticing any kind of chemical smell?
    Thanks again,
    Dave
  12. naterprius
    1,843
    I'm thinking it's the "fabric protection package" or something the dealer is doing.
    Nate
