Test Fit of Wheels on a Prius c
Discussion in 'Prius c Accessories and Modifications' started by kkim, Mar 27, 2012.
  1. B. Roberts
    B. Roberts Hypah Milah! Ayuh.
    682
    199
    used to be "Glacial" Maine and now FL
    I would do the wheel change myself. I always have. You might find a good shop or dealership to install your new alloy wheels, but sometimes you'll run in to the situation where an employee is in a hurry, leading to cosmetic scratches, lug over tightening or worse.
    I also like to use an old fashioned lug wrench, instead of a gun to install or take off a wheel. It also becomes a good opportunity to buy a quality torque wrench, too. I've seen plenty of damage to nice looking new wheels from careless installations.
  2. kkim
    kkim Active Member
    386
    130
    kauai, hawaii
    2 people like this.
  3. mccal
    mccal Junior Member
    42
    BayArea
    How about the Prius Performance Package wheels? Does Prius C has the same bolt pattern with Prius? I was thinking of the optional 17-inch performance wheels on 3rd Gen Prius.
  4. F8L
    19,011
    4,060
    50
    Grass Valley, CA.
    No. The Prius Plus Package wheels are 5x100 with a 42mm offset. They will not fit the 4-lug Prius c.
  5. kkim
    kkim Active Member
    386
    130
    kauai, hawaii
  6. Tek55
    Tek55 Junior Member
    96
    Houston
    So 7 inch width will be ok I assume?
  7. TytaniumK
    TytaniumK New Member
    44
    Alabama
    Awesome Info, kkim....
    Thanks for posting all this delicious literature & photos/links!:cool::cool:
    Ty-K
  8. kkim
    kkim Active Member
    386
    130
    kauai, hawaii
  9. DarkC
    DarkC New Member
    Been driving on 5x7 wheels with original stock tires for over 2K miles now and have had no issues whatsoever with the fit. Purchased the rims from discount tire and took it back 100miles after installation for a follow up to tighten wheel nuts as advised - I ask for an inspection to ensure no rubbing and they found none.
    Just had to replace the ugly steel and plastic hub caps. I think I took a slight hit in mpg performance but difficult to tell.
    Cheers!
  10. kkim
    kkim Active Member
    386
    130
    kauai, hawaii
    thanks for the feedback. what offset are those wheels and would you happen to know the weight of them? Car looks really nice! :thumb:
  11. SSG S
    SSG S Junior Member
    34
    ROSEMEAD CA
    Those wheels look really nice Dark C. Good job.
  12. DarkC
    DarkC New Member
    Thanks. Offset is +38.00mm. Weight, not sure but MB wheels website claim 20lbs for all wheel sizes of this model which can't be accurate. Im curious myself about that; I'll weigh this weekend and get back to you.
  13. Further
    Further Junior Member
    2020 Prius
    I've had my orange (ok habanero) Prius C2 for a week now and I love it. I've tinted the windows and a few other things and I'm thinking very seriously about getting these wheels. They are TRAKlite Burn. All the measurements seem to add up. But I'm a bit concerned about the center cap. Anybody have a guess as to whether these will fit the Prius C?
    TRAKLite Burn Wheels - Set of 4 by TRAKLite
    Thanks!
    Daniel
  14. F8L
    19,011
    4,060
    50
    Grass Valley, CA.
    I think the 15" "Burn" has a 40mm offset which should fit.
  15. filipinoof07
    filipinoof07 Junior Member
    66
    So for those who are still driving around in the steel-y's... what kind of improvement in fuel efficiency could we expect to see if we switched to something like those Konig's?
    The savings in weight is the difference in the Konig and the steel wheels right?
  16. WD0AFQ
    WD0AFQ Active Member
    619
    151
    Dexter, Mo.
    I bought the wheels before I got the car home. So, I can not tell you about any savings. I doubt there will be any noticable difference as long as you keep stock tires. I just can't do hubcaps on any vehicle myself.
    Dan
  17. Hyper_PriusC
    Hyper_PriusC Member
    83
    San Jose, CA
    I think your car looks great with those honda FIT wheels. I prefer these hatchback cars looking like toys. IMO if your car is lowered, it would look even better with those wheels.
    I've been running the Volk TE37s since the day i picked up this PriusC back in Nov 2012. I can't really compare to the stock steelies much since i only drove the steelies home from the dealer and that was the only time it was ever on the car. All i can say is these super light wheels are awsome. vehicle's handling, acceleration, and pickup speed is great.
    It maybe due to my existing tire diameter is smaller than stock, I average about 48mpg in city driving. I'm waiting to wear them out so i can put my stock tires and tpms on. I'll report back again about my results then.
    my wheel specs are
    offset: +39
    bolt pattern: 4x114.5
    weight: 8.5 lbs
    tire size: 195/50/15 (1.3" smaller in diameter than factory's 175/65R15 )
  18. Priusxrs
    Priusxrs Junior Member
    61
    Pa
    I got some cheap no name brand wheels they are 17x7 205-50-17 pirelli p6 all season tires weight 39.5 with tires. When I did the math on my mpg seemed that I lost around 3-4mpg on my daily drive to work...but they handled alot better then the stock stealies. It would be interesting in seeing some lightweight wheels and the mgp difference with lightweight wide. Might still have drag issues to affect the mpg of the wider tires.
  19. Mikej
    Mikej Junior Member
    28
    2014 Prius c
    Those tires looks really good. Is your prius lowered?
  20. cyclopathic
    cyclopathic Senior Member
    3,281
    536
    2014 Prius c
    The MPG reduction is mostly due to reduced sidewall height and non-LRR tire
Loading...
