Tested out TRAC, VSC, ABS tonight!
Discussion in 'Gen 3 Prius Main Forum' started by Tideland Prius, Oct 13, 2009.
  1. aapoppa
    aapoppa formerly known as "Popoff"
    142
    NC Mountains
    Oh well, at least I tried.:)
  2. raidbuck
    raidbuck New Member
    133
    Baltimore ,MD
    I was worried about winter driving, but I keep noticing all these Prii on the road in snow areas so it must be OK. Well, that's my rationale for staying with my OEM tires this winter.
    Rich N.
  3. Tideland Prius
    16,668
    If you wish. My videos were done with winter tyres.
  4. peirhead
    peirhead Junior Member
    48
    PEI Canada
    Tideland..did you notice if any of the stability control systems have any effect when your foot is on neither the throttle or the brake? I mean if you back off the throttle entering a corner on ice/snow and just steer through the corner without touching the brake...do any of the systems come on? I ask this because I thought they would/should, but in some testing over the holidays I didn't seem to be able to get any respose under these conditions!
  5. Tideland Prius
    16,668
    It should. If you power into a corner that's slippery and take your foot off, if the car slides, it's still gonna kick in to bring you back to your intended path.
  6. Jim Clark
    Jim Clark Member
    310
    22
    Northern VA, the 51st state (someday)
    Tideland:
    Did you try braking (kicking in ABS) while cornering? If so, did it maintain the turn or plow straight ahead?
  7. PaJa
    PaJa Senior member
    678
    116
    92
    Czech republic
    It will try to follow your driving idea, if physics allows. As always - winter tyres rule.
  8. peirhead
    48
    PEI Canada
    OK I guess I was a bit too timid when I was trying to get the system to kick in. Yesterday i found a good safe snowy place to try it again, and yes as expected the VSC kicked in while I was coasting through a corner with my foot on neither the gas or the brake. I did have to approach the corner agressively, and then using no brakes or gas I turned sharply into the corner....I couldn't exactly tell which wheels were getting the braking but it definitely kept me from starting to spin out...works great!!
  9. Tideland Prius
    16,668
    Nope but it should understeer slightly then regain grip once VSC kicks in.
    Yup. I use more steering angle. It's safer than more speed :)
