Testing and replacing individual battery blades
Discussion in 'Newbie Forum' started by Edward F Kreibick, Aug 6, 2017.
  1. Edward F Kreibick
    Edward F Kreibick New Member
    Warminster, Pa.
    I have a 2005 Prius with 110,000 miles. Replaced 12 volt at 75,000 miles. Red triangle with exclamation point and check engine light came on last week. Decided to remove hybrid battery pack and test individual cells. Lowest battery blade voltage was 6.43. All others are 7.55 volts up to 7.66 volts. Should the battery blades be tested under a load? How would you test under a load? Would one bad cell at 6.43 volts cause the red triangle and check engine light? I wish to learn and do my own repairs.
  2. Edward F Kreibick
    Warminster, Pa.
  3. jeff652
    jeff652 Senior Member
    607
    624
    Idaho
    This will help you with load testing modules:
    ProlongĀ® Battery Module Load Tester User Guide - Hybrid Automotive
    You also might consider our reconditioning systems to easily & efficiently cycle the pack after replacing the failed modules, and to maintain the battery so you don't have to replace other modules later:
    What causes hybrid batteries to degrade and fail? - Hybrid Automotive
    RCO and Prodigyplace like this.
  4. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    Hello and welcome to PC. Yes that voltage in one module would cause a fault light/code.
    Go to the Gen 2 forum and search the sub-forums for everything you need to know about battery repair. Bottom line: it's a cheap but temporary fix.
    GOOD LUCK!
  5. Prodigyplace
    12,715
    11,848
    Central Virginia
    Welcome.
    Follow @jeff652 's advice in your other thread. He is one of our hybrid battery experts.
    RCO and Raytheeagle like this.
  6. bisco
    52,862
    welcome!
  7. Sam Spade
    Sam Spade Senior Member
    2,036
    1,024
    2017 Prius c
    So where did this term "blades" come from when talking about battery cells ??
  8. kenoarto
    kenoarto Senior Member
    398
    Chicago, IL
    I like blade.
  9. jeff652
    607
    624
    Idaho
    blade=module=blade
    six CELLS per module
    Two MODULES per block
    Fourteen BLOCKS or twenty eight MODULES per Gen2/Gen3 Prius battery pack
    Raytheeagle, RCO and Prodigyplace like this.
  10. Sam Spade
    2,036
    1,024
    2017 Prius c
    Yes but where did that term COME FROM ?
    I've never heard it used relating to batteries before.
    And I ain't no spring chicken.
  11. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    Did it originated from lead acid accumulators with a blade electrode suspended in H2SO4?
  12. Sam Spade
    2,036
    1,024
    2017 Prius c
    Maybe. But if it DID, that bears no resemblance to how things work now.
    I find it interesting how different people use different terms to describe things; some of which are old, outdated and archaic and just tends to confuse things.
