Testing integrated relay
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Triadman, Jun 1, 2021.
  1. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    NO. BAD assumption.
    Is this in or out of the car ?
    What function and range is the meter set on ??
    Sounds like you are in way over your head.
  2. Triadman
    Triadman New Member
    North Carolina
    What is the location of the fuses? The relay checked out good. Thanks for the correct connections.
  3. Triadman
    Triadman New Member
    North Carolina
  4. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,095
    Columbia, SC
    He was a bit less snarky than others may have been. You guys were cutting his azz because you misunderstood the diagram and didn't understand what he was trying to say about connecting power. I think he went easy on ya!
    jerrymildred likes this.
  5. sam spade 2
    7,035
    2,804
    2017 Prius c
    THIS.
    Another case of asking the wrong question in the first place.
    And people ranting on and on, even after the discussion should be "reset" and started over.
  6. Triadman
    Triadman New Member
    North Carolina
    I am in way over my head. But I just needed a little guidance. I got the test done with RJs help
  7. rjparker
    rjparker Tu Humilde Sirviente
    11,066
    6,936
    Texas Hill Country
    Check post 20
  8. Triadman
    Triadman New Member
    North Carolina
    Sorry I missed the diagram. Let me see if I’m smart enough to read it
  9. Triadman
    Triadman New Member
    North Carolina
    I have voltage on the 15 amp. I also have 8.87 volts at the car side of the wiring harness between the two black wires that control the heater. I cleared the codes and drove it and so far I’m only showing P0038.
  10. rjparker
    11,066
    6,936
    Texas Hill Country
    Here is the entire procedure for testing for excessive O2 heater current. Given the situation, I would focus on the sensor and the splice that may have been made. If a mechanic did this work, I would take it back to them. Some would question the sensor especially if it was not original Toyota.
  11. Triadman
    Triadman New Member
    North Carolina
    I’ve got all of that information. That’s why I was down to testing the relay. The sensor is a denso. There was no splice made the thief cut the wires on the sensor side of the harness so I just replaced it. It checked out with the test provided. I am the mechanic lol
  12. Triadman
    Triadman New Member
    North Carolina
    Would you still question the sensor even though it was in specs on page ES 79?
  13. rjparker
    11,066
    6,936
    Texas Hill Country
    So did you run through all four tests in the procedure? Obviously the thread started out with the closed efi contact resistance measurement of step #2, but how did the other three tests go, starting with the sensor's heater element resistance of step #2? I know you said it was in specs.
    #33 rjparker, Jun 2, 2021
  14. Triadman
    Triadman New Member
    North Carolina
    That test was 17.4 ohms at 74 degrees air temp
  15. Triadman
    Triadman New Member
    North Carolina
    I haven’t done the other 2 yet. That involves dash disaassembly to get to the ecm
  16. rjparker
    11,066
    6,936
    Texas Hill Country
  17. James Analytic
    411
    63
    Michigan
    I just replaced the downstream O2 sensor with Denso and cat with Auto Shack on my 2006. That removed the two codes for the bank 1 sensor 2 related 2 downstream codes. Still throwing the P0031 code and P2238 AF Ratio sensor low pumping current circuit related code.
    What's baffling to me is how the sensor operates internally, at least first comparing with the gen 3 similar AF Ratio sensor where the Inspection document notes a resistance for the HT+ and AF- as being 10Kohms or higher.
    So, I tested my salvage yard Denso looking sensor and appears to be within spec ~2.8Ω if using the gen 3 inspection document for the Air Fuel Ratio Sensor. I just went to the local Autozone and tested the 234-9056 connection and am getting the same results in spec ~2.5Ω, albeit slightly lower heater element resistance. Both HT+ to AF- sensors don't show a reading no matter how how I go so like open is OK I'm guessing.
    Maybe there needs to be another like combustion exhaust gas with high enough temp condition to verify the AF pins results like I don't understand right now. Seems open testing. I'm probably over thinking and want to know how the AF pins sensor operates.
    Reads like the ACTIVE TEST A/F CONTROL operation inspection procedure needs to be performed.
    Wondering, what's the "hand held tester to the DLC3"?
    If the "hand held tester" can be a Techstream, or reads all the ECU codes equivalent enough to Techstream, OBD2 reader, what's the DLC3?
    Can Techstream somehow read and display the same data as the "hand held tester?"
    Higher temp, maybe higher resistance, though reads out of spec. from what I'm reading seems.
    I think I have everything document wise for my situation P0031 and P2238 codes where:
    - For P2238 is titled "Diagnostics - SFI System 05-327"
    - For P0031 is titled "Diagnostics - SFI System 05-79"
    O2 and air/fuel ratio sensors | Page 2 | PriusChat
    What threw me for a curve was first reading the gen 3 upstream sensor "Inspection" document that I'm not finding at the moment that I think @Patrick Wong posted.
    Anyone know of a quick check or method they found to narrow down?
  18. ChapmanF
    19,002
    Data Link Connector 3 is just the thing under the dash where you plug your diagnostic tool in.
    James Analytic likes this.
  19. James Analytic
    411
    63
    Michigan
    Wow, albeit I don't have much (OK none) blonde hair left as it's all decided to fall out, I feel a blonde moment. I'll try to re-read the document a couple more times when I'm not all doing body work.
  20. douglasjre
    douglasjre Senior Member
    2,250
    751
    Null, NL
    Why does that part say "made in china?"
