testing mfd screen without car
Discussion in 'Gen 2 Prius Main Forum' started by kennyd, Aug 10, 2018.
  1. kennyd
    kennyd New Member
    pa,usa
    hi guys, so when I find a display screen for a prius how do i test it outside of car. I have a battery to test it, i just need to know what wires are positive and negative so I can test it at the junkyard before buying due to no returns after buying. thanks so much.
  2. ITBland
    ITBland Active Member
    433
    272
    New Orleans, La area, US
    @kennyd , here is the pinout of the M13 connectors on 2004-05 and 2006-09.
    On 2006-09 MFDs, Pins 2, 3, & 10 need +12v, pin 1 is ground (-). If I recall correctly, I have tried to power up a spare MFD and it did not work, so I suspect that there is a "start" signal that I missed. (I also may have had a bad test lead :confused:.) Or, the ILL +/- wires may also need power and ground. I was going to try 12v+ on pin 17 and see if that was the missing signal, but it might need a data link to the Combination Meter. (I'm in the middle of a big project and my spare MFDs are a little buried right now.)
    A nav screen will work if you don't have nav (if you press a nav button it will just say something like "External device not connected") but the regular hybrid functions will all work.
    If your MFD has an M14 connector, then the nav MFD may have a different size M14 and you would lose bluetooth (if you have it.)
    If you have JBL, pay attention to the M14 pin count!
    Anyway, most Pick'N'Pulls have a 30-day guarantee, but most will only give "store credit"
    Good Hunting!
    #2 ITBland, Aug 14, 2018
    Raytheeagle likes this.
  3. ITBland
    433
    272
  4. ITBland
    433
    272
    If you put power on the six main wires, it will boot up and work. I have confirmed this on a 86110-47081, I believe it will also work on the newer MFDs (86110-47230).
    On the 86110-47081, on the M13 connector, put
    12v+ on pins 1, 10,11, & 12 and
    GND on pins 2 & 3
    on a 86110-47230 (or any 2006-2009 hi-res screen), on the M13 connector, put
    12v+ on pins 2, 3, 10, & 12
    GND on pins 1 & 11
    OahuPrius likes this.
  5. ITBland
    433
    272
    UPDATE:
    Verified That the 86110-47230 does work AND all you need is the Yellow and Gray power wires, and you can ground the metal case, so:
    for lo-res models (86110-47080, -47081, -47070, and -47071) connect pins 11 & 12 to 12v+ and ground the case,
    for hi-res models (86110-47210, -47230, and -47220) connect pins 2 & 3 to 12v+ and ground the case.
    germanaudiotech likes this.
  6. germanaudiotech
    germanaudiotech Junior Member
    Can the Low-Res Monitor from a 2004-2006 Prius fit in place of a High-Res monitor from a 2006 - 2009?
  7. 06PriusResto
    06PriusResto Junior Member
    17
    middletown ny
    I tried this with mine, it did power on but i only got the toyota logo illuminated for a few seconds and then it went dark. Did it stay on when you tested yours? How did it respond?
  8. 06PriusResto
    17
    middletown ny
    Im presently trying to test mine. I only connected pins 2 & 3 to 12v+ and grounded the case.
    All it did was illuminate the toyota logo briefly and then went blank.
