Testing MPG with 17s vs. 15s
Discussion in 'Gen 3 Prius Accessories and Modifications' started by F8L, May 20, 2012.
  1. wick1ert
    wick1ert Senior Member
    1,311
    183
    Delawhere
    Mike, I believe it's around 110ish.
  2. WE0H
    WE0H Senior Member
    3,247
    528
    Awesome :) Even a Two with good tires set to 45psi is rock solid at 100mph :) Next season when I get enough miles on my car to say it's broke in, I'll take her out and find that limiter :)
    Mike
    iPhone :)
  3. 32kcolors
    32kcolors Senior Member
    5,683
    954
    124
    Redondo Beach, CA
    If you're on a downward incline, you can go a bit faster than the limiter and it'll be reflected in the speedometer.
    WE0H likes this.
  4. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    I finished off the tank after swapping tires with Mike and with a little aggressive driving at 70mph as well as 65mph morning commutes the tanker indicated 50.something mpg. My morning commutes have been terrible since I stopped trying and even at only 65mph I saw 44mpg yesterday and 42mpg today. 50mpg is still totally achievable with the 17s even with my unfriendly commute but you really do have to nurse it along to maintain mid 50s whereas you don't even have to really try to get mid 50s with the Energy Savers. It can't decide if I want to switch back to my Ascends or just run the 17s out until winter.
  5. SoCalBPrius
    SoCalBPrius Active Member
    563
    118
    SoCal
    That's 1 thing that is noticeable to me is that on freeways, it is so hard to maintain or gain mpg's on my 17's even at minimum speed limit:(.
  6. WE0H
    WE0H Senior Member
    3,247
    528
    I just accept that the car looks freakin cool with the fancy wheels and is gonna get less mpg's than a regular Prii would get. It's still a hell of a lot better than any other car on the road :)
    Mike [​IMG]
  7. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    This morning I kept my speed at 60mph and tried hard to keep mpg up but despite decent temps in the high 50s I was only able to achieve 46mpg for this 48mile segment. I was sitting at about 51mpg before I hit the large hill. At this point with the 15" Energy Savers I was over 60mpg with the same driving technique. With the Energy Savers I would end this segment around 53-54mpg. So I'm still seeing the average of about 3mpg loss vs. the AVID Ascend in the same conditions and a 6+mpg loss vs. the Energy Saver A/S.
    I have to make a long trip up the coast this weekend so I'll likely swap back to the 15s today. I'm not sure I'll be putting the 17s back on. Anyone local want to buy a set of 17" wheels/tires and 15" AVID Ascend tires? LOL
  8. wick1ert
    1,311
    183
    Delawhere
    How's the ride quality (noise, comfort, etc) compare between the Ascend and ES A/S tires to you? I'd expect the 17s to be a little noisier and harsher. Typically harsher is the case with the low profiles, because there's less rubber to absorb the vibrations and bumps.
  9. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    The ride quality and noise is better on the Energy Saver A/S but the handling and steering feel is much better on the AVID Ascend. To me the Ascends feel like something in between the 15" and 17" tires. They ride sorta like the 17s. They are definitely harsher than the Energy Saver A/S but those tires feel well, mushy.
    wick1ert likes this.
  10. Forrest80
    Forrest80 New Member
    Santa Rosa
    Was the total weight of each tire+wheel set up posted?
    I seen the posted weight of the 17 inch wheels.
  11. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    Weight for 15s:
    AVID Ascend 195/65/15 = 21lbs
    OE 15" Wheel = 15lbs?
    36lbs
    Weight for 17s
    Primacy MXM4 215/45/17 = 21lbs
    Centerline RPM 17x7 = 15-16lbs
    36-37lbs
    I never weighed the new setup on a scale but I have weight the 17" wheels with Kumho Ecsta ASX tires in the past and the weight was around 37-38lbs. The Kumhos are rated at 22lbs so this sounds about right. The OE AVID S33D is 18lbs so the OE combo should be about 33lbs. From what we can tell, weight plays a minor role in mpg for these cars. Otherwise the OE 17" 24lbs wheel would really kill your mpg. :) The OE Toyo Proxes A20 215/45/17 tires weigh 21lbs like the Primacy MXM4.
  12. Forrest80
    Santa Rosa
    I read some where else on these forums stock set up is 33 pounds also.
    My goal is just for increased handling/saftey:
    MOTEGI RACING MR125 16x7 15.8 lbs.
    205/55-16 Bridgestone Ecopia EP422 91H 19 lbs.
    34.8 lbs. together.
    I notice with all my cars what really dictates my mileage is city mileage and these hills I have to travel through for my daily commute. The Low Rolling Resistance concept is new to me though. I can see how 17's during highway would continue to roll with ease. So as long as you can travel long distances at 55mph you wont see much of a difference. That’s something I am unable to do on my daily commutes.
    If you were to travel my route where acceleration is used more often with hills and more city than highway, how well would a heavier set up fair? My guess is with my habits not so great.
    My other train of thought is I could benefit from nicer tires and continue to use stock wheels.
    What do you think F8L?
  13. The Critic
    The Critic Resident Critic
    3,193
    2,330
    CA
    City drivers will benefit the most from LRR tires. Highway drivers will not see much of a difference, from my experience. You probably will not see an increase in handling with the EP422; I would instead consider the Primacy MXM4 in that size.
  14. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    It is a common misconception that a 17" tire will not induce losses at highway speeds or that a LRR tire will not have much of an effect at highway speeds. My commute is 98% highway yet I can definitely see a difference between tires. I can watch my scan gauge and observe changes in real time as well. The Critic is correct in that LRR tires benefit you the most at lower speeds because RR plays a larger role in fuel economy than wind drag does at low speeds BUT it still plays a role at high speeds too. It is simply shadowed by aerodynamic drag. In city driving conditions I would focus first on the best LRR tire you can use and then weight. a good 16" wheel with the Energy Saver A/S or maybe the Ecopia EP422 would be a very nice combo for appearance, safety, performance and fuel economy. :)
  15. Forrest80
    Santa Rosa
    Thanks Critic and F8L for the response. I will compare Energy Saver A/S verse EP422. At tirerack rack people rate the AVID S33D way lower than EP422 so I figured it was a upgrade.
    I want 17's real bad but I have to be realistic. I bought this car for gas mileage.
  16. WE0H
    WE0H Senior Member
    3,247
    528
    I run 46-49 mpg with my 17's driving normal at or slightly above posted speeds. It's not like the 15's would do but the car looks amazing with these wheels/tires. Good enough for me [​IMG]
    Mike [​IMG]
  17. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    You can do quite well with the 17s if you drive conservatively and choose the right wheels/tires. I mean you bought the car expecting 50mpg right? Well you can do that with the 17s if you try hard enough and your commute is not terrible. It seems like only a 2-4mpg difference between a good sets of 17s and the OE 15s. Socal has a bit of a different case because he is running a wider non-LRR tire so I'm sure he suffers a bit more of a hit vs. OE 15s. The pain beings when you start thinking about what you could get with a set of Energy Savers vs. 17s...... lol
    Tell me this. How many miles do you drive each year? If it is less than 15,000 then just bite the bullet and get the 17s. The economic cost difference is quite low and could be less than $10/mo. depending on what tires you choose and their life expectancy. Just don't go running numbers vs. a 15" Energy Saver vs. the 17s or else the lifetime cost will be over $2,000. ;)
  18. Forrest80
    Santa Rosa
    Year 1 will be about 10k miles. year 2 will be about 10 Miles. year 3 will be about 30k miles due to I will be traveling a further distance to go to school. Will factor it all in and see what I come up with when I am ready to buy the wheels. Still need to do tints, font and rear sway bar and possibly front tower brace.
  19. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    I'm glad to see you have made up your mind: numbers over beauty :)
    At least until the next test ;)
  20. SageBrush
    11,627
    2,533
    Southwest Colorado
    Justin, you are infecting me with your infernal tyre swapping.
    It just occurred to me that I could swap the 15/Hydroedges on my Prius with the 17/MXM4 on my CTh for the dry months, and swap back for the winter. Since the CTh is used for my long distance driving this would let me enjoy better fuel economy when the roads are dry, and better traction in the winter.
    Any guesses how much noisier/rougher the CTh will be with the smaller tyres ?
    F8L likes this.
