Texas Starship Testing
Discussion in 'Environmental Discussion' started by bwilson4web, Nov 24, 2020.
  1. bisco
    52,812
    i think they should take non refundable deposits to live on mars
  2. Mendel Leisk
    42,310
    The object of this is to set up a base on the moon? Seems like a lot of resources devoted to pie in the sky.
  3. bwilson4web
    16,523
    Driving back from Texas, I had a Gedankenexperiment. Today, long range artillery rockets and missiles have a high explosive warhead. But if it were oxygen and methane fueled, the uncombusted reactants could be mixed as it approached the target and then ignited. Such a weapon would have a variable, explosive yield trade-off with range.
    The weapon would also be exceptionally light, with more than an order of magnitude, warhead effect. The rocket could use a simple pressure feed system with the thicker body becoming the shrapnel. This would allow a family of rockets from smaller, ATACMS to substantially larger, airport and refinery targeting missiles. Should also work an bridges, especially rail road bridges.
  4. Mendel Leisk
    42,310
    Expend some of the fuel in an explosion? It's been done:
  5. fuzzy1
    10,691
  6. bwilson4web
    16,523
    Similar idea but using 100% O{2} instead of 20% O{2} and 80% N{2}.
    There are non-trivial problems such as the boiling points, O{2} (54-90 K) and methane (91-112 K). Solvable with pressure management and given it would be in a single body.
    A nice technical write up on the type of rocket: Introduction to PROMETHEUS - ARIS.
    Replace ethanol with liquid methane:
    As a munition, a much simpler, cheaper system would be used. Light weight pressure tank with a thin, internal baffle separating the liquid methane and oxygen. A small explosive can eliminate the baffle for mixing. At the rear, a simple, one time use, engine and control logic.
    As the missile ends powered flight, blow the baffle to mix. Then just prior to impact, open valves to engine and fire the igniter. It should make an impressive bang with plenty of shrapnel.
    #86 bwilson4web, Jun 8, 2024
  7. fuzzy1
    10,691
    I'm wondering how explosively removing the baffle for mixing, and igniting the mixture, can be kept as separate events for different points in time. It seems this might be considerably more difficult in a 100% fuel-and-oxidizer environment than in the 80% inert N(2) environment of thermobaric weapons.
  8. bwilson4web
    16,523
    Absent experimentation, I’ve assumed a very, high speed explosive In possibly a sealed, thin tube. Just enough to rupture the baffle but not the outer casing. But there are non pyrotechnics that could work too.
  9. fuzzy1
    10,691
    Hmm. I wonder what our military's mix of fuel types is, for its rocket and missile inventory. Cryogenic liquids vs room temperature liquids vs solid fuels.
  10. bwilson4web
    16,523
    Ours since the Titan was retired, are solid fuel. Less performance per pound than liquid fuel, they are a whole lot easier to store and fire.
    The one exception are military payloads launched to orbit. But those rockets are contracted to established, liquid fuel, rocket providers.
  11. fuzzy1
    10,691
    So, no warhead-carrying missiles to modify to this proposal.
  12. bwilson4web
    16,523
    Correct. I'm thinking of the Ukrainians. They are clever people (as the Russian are learning,) and a simple missile as outlined should easily reach deep, 300-1,200 km, into Russia to deliver a powerful, binary liquid fuel explosive, the unburned propellant. Mechanically simple using LOX and LNG as both propellant and warhead.
  13. fuzzy1
    10,691
    I had understood that warheads are usually high explosives, which detonate. I had understood rocket fuels to be generally in the low explosive category, which deflagrate. Yes, lots of energy and spectacular fireballs with nasty pressure waves, but not the same sort of shock waves normally preferred for military warheads.
    Do others here have a different understanding?
    Entertainment movie 'explosions' seem to lean towards the deflagration type, for the impressive fireballs, but I've generally noticed them lacking signs of the hard shockwave and vapor condensation shell in the trailing low-pressure wave seen in non-entertainment films of high explosives.
    #93 fuzzy1, Jun 10, 2024
  14. bwilson4web
    16,523
    Found an interesting paper: https://arc.aiaa.org/doi/epdf/10.2514/6.2019-4283
    Synopsis of LOX/Liquid Methane & Liquid Natural Gas Rocket Propellant Explosion Hazards
    Alan M. Sutton!, Claude E. Merrill?, and Nils M. Sedano Air Force Research Laboratory, Edwards AFB, CA 93524, USA Alexandra M. Ortiz*461$ FTS, AFTC, Edwards AFB CA 93524,
    USA Liquid Oxygen LO2, and Liquid Methane (LCH.) or Liquid Natural Gas (LNG) are liquid rocket propellant combinations receiving much interest. To date, no methane fueled launch vehicle has flown, although some small experimental demonstrators have conducted successful free flights.[1] The proposed use of this propellant combination in contemporary launch vehicles has created a need to determine the propellant explosion hazards. Quantification of the explosive energy release is needed to facilitate proper planning of range safety, launch facilities construction, and test site layout. As part of this estimating process LOMethane theoretical and thermochemical modeling of energy release are examined and compared to operational propellants, including discussion of the legal and regulatory consideration and historical methods of determining net explosive weight. Unlike established propellants (e.g. LO/LH2 and LO/RP-1) that do not have a common temperature and pressure liquid range, the LOz/Methane propellant combination offers a unique condition where the propellants share a similar liquid state.
    Although not perfect for my purposes:
    BTW, engine "knock" is a detonation of the fuel air mix, typically regular fuel at ~13-14 atmospheres. The body of a the simple rocket would be at much higher, engine chamber pressures, typically +200 atmospheres. Detonation won't be a problem.
    #94 bwilson4web, Jun 10, 2024
  15. bwilson4web
    16,523
    About Starship, rumors are:
    • Flap hinges will be moved and better protected with an improved tile barrier.
      • IMHO, aerodynamic structures like wings should not be put on space craft.
    • An under, ablative layer behind the tiles to handle tile failures.
      • Sensible given how one tile failure should not cause vehicle loss on re-entry.
      • This is a solvable but not trivial engineering problem.
  16. tochatihu
    tochatihu Senior Member
    9,963
    3,846
    Kunming Yunnan China
    2001 Prius
  17. bwilson4web
    16,523
    4 PM, CST.
    So the dog and I put the car on a free charger and had a 12” breakfast taco:
    I was reminded how much of the world eats without utensils followed by chopsticks and then forks/spoons.
    High winds, sunny, and warm this Monday. The Tuesday launch has weather challenges as a cold front is expected Wednesday. Such is life on our planet.
  18. ETC(SS)
    7,523
    +1 on the trip report.
  19. bwilson4web
    16,523
    Drove out to see the beast:
    Photos are good but real-life is awesome. Imagine 10 railroad tanker cars welded together and stacked on one end.
    For supper and a free charge, I ate at a bar and grill. It was a joy to overhear engineering ‘bar talk.’
    #99 bwilson4web, Nov 18, 2024
  20. tochatihu
    9,963
    3,846
    2001 Prius
    "It was a joy to overhear engineering ‘bar talk.’"
    That would seem to be the place to hear it.
