Thanks for the 30k tips!
Discussion in 'Gen 2 Prius Main Forum' started by Prius 49, Apr 20, 2011.
  1. Patrick Wong
    18,210
    6,526
    You are correct, there is no oil level sensor.
  2. Mr.Vanvandenburg
    1,361
    665
    2020 Prius Prime
    The crank isn't churning in the oil, with oil at the full mark, not even close.
    I keep at full and spend a few dollars more to use synthetic oil. Sometimes I end up with the oil 1/8"over full, not a problem either, no mpg hit, no problems of any kind, nor will there be.
  3. sorka
    sorka Active Member
    1,034
    199
    Merced, CA
    2019 Prius
    Do a search on the forum. This has been hashed out many times before.
  4. Mr.Vanvandenburg
    1,361
    665
    2020 Prius Prime
    The crank does not touch the oil at the full mark, or even somewhat above the full mark. Only lawn mowers etc have such splash systems.
    Scroll down to nomograph, and then for the engine cross section. Posted several years ago. The crank is well above the full oil mark.
    The car is often delivered 1/8" overfilled from Japan. No harm, no mpg hit, nothing happens or is wrong.
    Do more searching yourself if still in disbelief.
    Prius Palm Mileage Simulator
