Thanks to the great Hobbit - 2004 MFD Fixed
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by jdenenberg, May 6, 2010.
  1. jdenenberg
    jdenenberg EE Professor
    3,870
    1,870
    Trumbull, CT
    2020 Prius
    LE AWD-e
    After 6 years and 172,000 miles (is this a record?) my 2004 Prius Multi-Functional Display (MFD) developed the classic failure symptoms. Due to the Hobbit's great work and documentation of the cause and repair of this problem I was able to fix it (at least for now) at no cost.
    Hobbit's analysis and instructions can be found at: Prius MFD
    It took me a little over 2 hours to remove the MFD, disassemble it, re-flow the cracked solder connection (at 67 years old this was not easy - tiny wires, poor eyesight and unsteady hands), reassemble the dash and test.
    One thing I noticed was that AM radio static due to Prius electrical noise was reduced after the repair.
    JeffD
  2. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    2,999
    Fort Lee, NJ
    Congrats!
    2006 to 2009 models have a different MFD (with higher resolution). I wonder if that same issue was fixed.
  3. qbee42
    qbee42 My other car is a boat
    18,058
    3,075
    Northern Michigan
    So far that appears to be the case.
    Tom
  4. Patrick Wong
    18,200
    6,482
    It's great that we have a Hobbit and a Bear (as well as many other PC members who aren't represented by a fiction character) who provide great advice regarding how to keep our Prius running!
    Meg&Bear likes this.
  5. jdenenberg
    3,870
    1,870
    Trumbull, CT
    2020 Prius
    LE AWD-e
    The design change in early 2005 models fixed the major cause.
    JeffD
  6. usbseawolf2000
    14,487
    2,999
    Fort Lee, NJ
    I was just wondering because TheForce has 2006 and his MFD just failed. Hobbit needs to get a hand on it. ;)
  7. DGH
    DGH Thread Terminator
    365
    93
    Wales, WI
    Patrick,
    Add yourself to the list, you modest son of a gun.
    And please don't get rid of your Gen2 until I get rid of mine.
  8. Patrick Wong
    18,200
    6,482
    Thanks, that is very kind of you.
    I'll probably own a G2 for at least three more years. By then I am sure that all possible G2 failures and solutions will be well-known, given the large number of G2 in service.
  9. patsparks
    10,664
    567
    Adelaide South Australia
    Gotta love the Hobbit, I fixed my MFD about 2 years ago I guess and it is still going strong. Not wanting to stuff the board up all together I engaged a professional to solder mine, at great expense, $25 AUD!! It is the only repair I have carried out on my Prius since purchase in 2007.
  10. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,341
    920
    251
    Surprise, AZ (Phoenix)
    Did mine the same way about 6 months ago when it started to go on the '04. The Mrs. didn't like losing NAV or the ability to see the A/C adjustment.
  11. andyprius
    andyprius Senior Member
    2,212
    188
    Sacramento, California.
    I totally concur with that! and you too, Pat.:rockon:
  12. butzodaddy
    butzodaddy Junior Member
    Thanks also from me. I've done this repair twice, the second time it didn't seem to take. Eventually I found that pin 60 on the mating board connector had a cracked joint. It was the only cracked joint on that side but it was enough to cause intermittent malfunction. So while you have your unit disassembled, take a look at that other connector as well.
  13. Twally
    Twally New Member
    SLC, UT
    My wife's Prius had the MFD problem that so many had and I found the walk through by Hobbit about the most likely common error and fix. I went to town and had it out in under 45 minutes, and then took it to a guy who specializes in electronics. He soldered the board for me, and now I'm trying to piece it back together and find myself with a wire where I don't have a place for. It really is my own foolishness for not having been more careful about my taking it all apart, but live and learn. If any one could point me in the right direction, I would appreciate it.
  14. Strafgod
    Strafgod Junior Member
    Got a little problem. I recently replaced my 86110-47070 with the 866110-47080 that Hobbit himself had examined and repaired when he created his now famous "Evaluation and Repair of a Failed Prius MFD". It worked, but no bluetooth or voice command and a 2 second high pitched beep after ignition, and the audio and climate buttons were non-functional. When I removed the non-functional 47070, I noticed that it had an extra wire than the 47080. It appeared to be a ground wire, but it didn't appear to be connected to anything. I did my very best at reflowing the solder at 58 and 60, but when I replaced the 47070, I got the red triangle of death.
    I put the 47080 back in, but could I have made an error by not knowing what to do with that extra wire?
    Love to hear ideas on this, because I find it hard to believe that my meticulous little foray into reflowing the solder could have made my 47070 *less functional* than it had been before I touched it.
    Thanks, gang.
    Larry
    2004 Salsa Red Prius
    55,000 mi.
  15. Strafgod
    Hey, Twally,
    I'm in that same situation. Did you get the red triangle of death when you put it back in without attaching that wire? Did you ever figure out where the wire goes?
    Thanks,
    Larry (Strafgod)
