thats enough, gonna be handing this car back once the lease is over in a year
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by prius123, Apr 29, 2011.
  1. prius123
    prius123 Junior Member
    35
    winnipeg
    Lately i heard this extra noise when going over bumps from the right front. Noticed when i was going slow if i'd move the steering left and right you'd hear it too. Brought it in today, when he calls me back he says its a couple parts that are loose, the rack and pinion 1300 with the steering and a control arm in the suspension 700. Its covered by warranty. So they'll give me a call once the parts come in.
    After getting those winter tires I wanted to keep it but thats enough and i'm going to be handing the car back once the lease is done in over a year. I'll have had a couple winters with the tires and rubber doesnt last too long. The mileage is at 53,000km and when handing it back couldnt be over 98,000 so looks like i'll make it. Got a crack along the bottom of the windshield, i'll have to look into if autopac could replace that and pay the 250 deductable.
    Wasn't sure if i should keep it but then i'd have to pay 10grand plus the warranty would be expired. Wouldn't be able to afford surprise repair bills on top of car payments. When i got the car the lease was for 4 years but the warranty was only for 3. So I paid 1000 for an extended warranty that lasts 4 years. Looking like it was a pretty good idea, with that brake actuator stuff that was ongoing and you know things like this 'll just keep getting worse. Haven't heard that brake noise when pushing hard lately though. So i'll see how that goes.
    Running it in the winter the engine keeps running because of the heater so not that far different than running a regular 4 cyl car. I could shut the engine off while keeping it running by turning the heater button off on the screen but if its past -20 it'll still keep running. So whatever's going on, i'm handing this thing back.
  2. DaYooper
    DaYooper Member
    106
    Sout of da UP eh!
    So what are you looking at instead, if you don't mind me asking?
    51,735
    i hear ya. that's a lot of problems. gonna get a 2011 or 12?
  4. sorka
    sorka Active Member
    1,026
    198
    Merced, CA
    2019 Prius
    Why on earth would any lease a Prius? The only way it makes sense to buy one is if you're going to keep it for a long time and put a lot of miles on it quickly.
  5. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    Sorry to hear of the problems. Seems a little like dealer gouging but since it is under warranty, no problem.
    Just as comparison, the majority of people have 0 repairs with 100k+ kms.
    It seems strange that the rack + pinion would give out this soon. Almost makes you wonder if something else caused it to fail. The windshield is easy enough to figure out. It was cold outside one morning, you turned on the defrost full blast, and wammo bammo you got a cracked windshield. Hardly the car's fault there.
    Have you thought about dressing for the weather and then you don't need full blast heat in the winter? Yes we get -20 and much colder. Be smart, wear gloves and a jacket. I keep the HVAC off the whole time even in the winter, but even if you set it to 25 or something you will net better.
    Something to consider is that in the winter, the Prius always starts since there is no starter. Being from Winnipeg, I am sure you are familiar of the car that just wont crank because the battery is too low. Happens even in sunny southern Ontario! :)
  6. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    Ever drive around Winnipeg? A lot of the streets resemble the Belgian Block road test course for US Army vehicles
    In particular, Dugald. Also Wellington by Grovennor. Most of St Mary's is just as bad
    The alignment was always going out in my Prius. The FJ seems to soak up the bumps and after 4 years, still has not needed an alignment
    As far as winter operation, living in this part of the country you MUST make a "winter front" and cover the grille. I even do that for the FJ
    The Prius doesn't have much waste heat. Once the temps are consistently -20 C, and certainly by -40, you have to cover the grille
  7. BAllanJ
    BAllanJ Active Member
    667
    78
    Kingston Ontario
    I cover the grill in winter even in southern Ontario, so I can bet it's necessary in Winterpeg... along with the block heater. I also play with the heater... off at stop lights so the engine will shut down,minimal use before the engine is over about 40c... It's a lot warmer here, but I figure if I'm dressed at all for the weather outside (and you should be) then I can survive in the car with just a bit of heat. If you wanted it as warm as your living room, stay there. I will remove my coat etc if I'm driving a few hours down the highway, but with the grill blocked there's always been enough heat available for me after not too long.
  8. Troyroy
    Troyroy Member
    373
    30
    Troy, NY
    Is it even possible to get a lease for 4 years with 60,000 miles.....then turn the car back in.?????
  9. qbee42
    qbee42 My other car is a boat
    18,058
    3,079
    Northern Michigan
    This is why I live in a warm southern location.
    Tom
  10. donee
    donee New Member
    2,956
    198
    Chicagoland
    Hi jayman,
    The Prius, like most cars, has plenty of waste heat. Its just the 2nd Generation car did not take advantage of it. The 3rd Generation resolves that with the exhaust heat recovery system.
    Not sure the Prius is a good car for rough roads driven at rally speeds , however. A real lightweight car, with a strong suspension is a must for that. An independant rear suspension is probably needed too.
