That's it!
Discussion in 'Fred's House of Pancakes' started by TonyPSchaefer, Feb 3, 2007.
  1. JackDodge
    JackDodge Gold Member
    2,366
    Bloomfield Hills, MI
    Bye, have fun, sign on when you get there...of course, we wouldn't notice the difference but heck, you'll be warmer. The earth might move or the weather will be really wild but it'll save you from freezing your butt off for a few months so if it's worth it, go for it.
  2. bigdaddy
    bigdaddy Member
    991
    Duluth Georgia
    <div class='quotetop'>QUOTE(TonyPSchaefer @ Feb 3 2007, 08:52 PM) [snapback]384985[/snapback]</div>
    If you look closely at that WeatherBug screen, you'll notice a link that says "Change Location." Click it, click it now!
  3. hill
    9,041
    <div class='quotetop'>QUOTE(TonyPSchaefer @ Feb 3 2007, 09:52 PM) [snapback]384985[/snapback]</div>
    South O.C. today: EIGHTY FOUR degrees. Help ... I need an ice cold coke to cool me down. Never mind, I'll just go down to the community pool (splashing sounds of relief ... and smugness). Oh, sorry. Whoops! Now I'm lieing. :p
    Excuse me while I go find another cold beer before the game.
  4. hycamguy07
    hycamguy07 New Member
    2,707
    Central Florida
    <div class='quotetop'>QUOTE(Godiva @ Feb 4 2007, 02:37 PM) [snapback]385191[/snapback]</div>
    during the summer it says warm low 80s and huuuuumid......
    We are happy to get a cold snap, if it freezes at night for 3 dys the mosquitios die :)
    We also get those GIANT yellow and black GRASSHOPPERS! <yuck> they make a cracking sound when you run them over with your car..
    Even if you dont see them, every home has palmetto bugs they hang out in the walls.
    And we have transplanted people from all over that cant drive, they do 55 in 65 mph zones..
  5. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    <div class='quotetop'>QUOTE(DaveinOlyWA @ Feb 4 2007, 03:10 PM) [snapback]385177[/snapback]</div>
    I actually adjust the temperature depending on ambient conditions. When it's hot outside, I let the temperature creep up to 77 or so before turning on the A/C. The colder it is outside, the colder I keep it inside. Even keeping the condo at 67, I'm still comfy in a tee.
    However my elderly father prefers much warmer temps, due to his arthritis, and since he moved in with me after my Mom died, it created a bit of tension between us. I finally found the solution though: for his bedroom I got an electric heater, since power here in Manitoba is quite cheap compared to other places in North America. So he can keep his room a stifling 78-80.
    About the only other occupant of my condo who likes that sort of temperature is my cat.
    In the living room I have a natural gas fireplace. My Dad will leave it on most of the day and soak up the heat. It's a fair compromise for all concerned.
  6. jayman
    13,439
    641
    Winnipeg Manitoba
    <div class='quotetop'>QUOTE(daniel @ Feb 4 2007, 04:08 PM) [snapback]385205[/snapback]</div>
    Yep it's an instinctive Survival Mechanism for Northern climates: flames are better than ice
    It was probably a Coleman then. A bimetal spring on the back of the heater allowed you to very roughly set the temperature. The burner well had enough oil to keep a "low" fire going, sort of like a pilot for a gas appliance. When the bimetal spring tightened up, it lifted the float valve and more oil flowed in, with a higher flame.
    Fancier ones used a thermopile and a millivolt thermostat on the wall to turn on/off the float. They also would work without power, as the thermopile works by heat.
    Sooting was a big problem with those heaters, as there was no inducer fan to force combustion air into the chamber. An oil furnace/boiler has much less sooting as the combustion air is forced, so the flame is much hotter.
    Like an oil lamp, the flames in a Coleman or similar oil heater are yellowish, and very sooty. The quality of fuel used was also important, highway diesel or jet fuel worked best, especially jet fuel as it usually has Prist or another anti-gel already blended in.
    I was a kid when my folks had such a heater in a very old house, and if I recall the instructions called for routine cleaning of the burner ring. That model also had an oil tank hooked to the back of the unit, which you would take outside to fill up. The house always stunk of diesel.
    Fond memories to be sure, but I'll stick with my comfy central system thanks.
  7. Michgal007
    Michgal007 Senior Member
    1,321
    98
    Macon, GA
    For 20 years, I was in tropical Sri Lanka (in a coastal city), around 80F and 80% humidity everyday.
    Then I moved to Tucson, AZ where it gets 110F and 5% humidity in summer.
    Now I am in Michigan where it is -14F today.
    Where should I go next?
  8. tleonhar
    tleonhar Senior Member
    1,541
    34
    Belle Plaine, MN
    <div class='quotetop'>QUOTE(DaveinOlyWA @ Feb 3 2007, 09:16 PM) [snapback]385006[/snapback]</div>
    Actually, we missed out on 2 months of bitching about the weather, so now we need to make up for lost time. :lol:
  9. nicoss
    nicoss New Member
    304
    Right Now for
    South Pasadena, CA (91030)
    Clear
    73°F
    Feels Like
    73°F
    Updated Feb 4 06:45 p.m. PT
    UV Index: 0 Low
    Wind: From E at 4 mph
    Humidity: 13%
    Pressure: 30.12 in.
    Dew Point: 18°F
    Visibility: 10.0 miles
    All freezing PRIites are welcomed to Kalifornia
    We are civilized, liberal, more-or-less friendly people.
    AND having Eastern PRIites move here will improve the gene pool :D
  10. jayman
    13,439
    641
    Winnipeg Manitoba
    Feh! Maybe it's the hard liquor talking, but beat THIS
  11. daniel
    14,487
    1,519
    Spokane, WA
    <div class='quotetop'>QUOTE(jayman @ Feb 4 2007, 04:55 PM) [snapback]385309[/snapback]</div>
    I don't remember if the thermostat was on the wall or on the heater. Control was not as precise as a modern thermostat, but it was pretty darn good. The worst problem was the leaky walls and windows: on windy days the floors were cold no matter what.
    I had no instruction book for that heater. But the fuel tank was outside, maybe a couple hundred gallons, and there was no smell in the house. The weak link was the portion of the fuel line from the tank to the house. Once I put heat tape on it it was okay.
  12. hycamguy07
    2,707
    Central Florida
    I guess its plain to see why everyone wants to move to Florida ;)
    Mon (hi/lo - rain chance)
    Feb 5 Sprinkles
    59°/46° 20%
    Tue
    Feb 6 Partly Cloudy
    66°/45° 10%
    Wed
    Feb 7 Partly Cloudy
    70°/53° 10%
    Thu
    Feb 8 Few Showers
    71°/51° 30%
    Fri
    Feb 9 Few Showers
    73°/51° 30%
    Sat
    Feb 10 Partly Cloudy
    73°/55° 10%
    Sun
    Feb 11 Partly Cloudy
    71°/53° 10%
    Mon
    Feb 12 Scattered Showers
    66°/56° 30%
    Tue
    Feb 13 Showers
    71°/58° 60%
    Wed
    Feb 14 Sunny
    75°/56° 10%
    Neeener, neeener neeeeener ! :p :lol: :lol: B)
  13. tleonhar
    1,541
    34
    Belle Plaine, MN
  14. Danny
    Danny Admin/Founder
    7,093
    2,122
    1,174
    Charlotte, NC
    2013 Prius Plug-in
    <div class='quotetop'>QUOTE(Godiva @ Feb 4 2007, 04:58 PM) [snapback]385246[/snapback]</div>
    Yeah, but you also get paid more to reflect your high cost of living. My job in California pays almost triple (yes, I've looked!). San Diego is like nirvana for me - no humidity, but still warm. I live in Columbia, aka the center of hell. Nichole gave me 2 options for our wedding - 1 was in May and 1 was in March. I chose the March one because it is the only time I have a chance of not sweating all the way through to my tux jacket - in the air conditioning!
  15. jayman
    13,439
    641
    Winnipeg Manitoba
    Well, it looks like our low temperature overnight tied a record
  16. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    ok Tony. so now you can brag since Chicago's weather made the NBC national news tonight...nice pix of the cutter breaking up the ice in Lake Michigan...
