the 12 volt outlet
Discussion in 'Gen 3 Prius Technical Discussion' started by Jim Calvert, Sep 16, 2009.
  1. Southern Dad
    Southern Dad Active Member
    350
    212
    58
    Monroe, GA
    Couldn't the Solar Battery Tender be connected to the battery in the back, with the solar panel in the back window?
  2. El Dobro
    El Dobro A Member
    7,102
    3,282
    I have a solar battery tender that plugs into the OBDII port for charging.
  3. hlunde
    hlunde Member
    419
    75
    This would work, but conductors would have to hinge with the hatch ...
  4. hlunde
    hlunde Member
    419
    75
    This works! I assume that the OBDII circuity has some kind of current limiting feature in case the collector or its conductors short. I would be happier with a fused circuit.
  5. El Dobro
    El Dobro A Member
    7,102
    3,282
    Here it is. VW uses them when they ship and store the cars so the battery doesn't die.
    12V VW SOLAR PANEL BATTERY MAINTAINER WITH OBD PLUG IC0915687D | eBay
  6. mtlewis
    mtlewis Tinkerer
    47
    Mississippi
    I have a question that is not exactly on the subject but I do not like to start new threads unnecessarily. I collect water from a spring in the hills of a neighboring county. My four containers total about 28 gallons. I bought a small 12v water pump that has spring clips designed to power the pump from a car battery. Would I risk any harm to my Prius if I left it on and use its battery to power the pump?
  7. El Dobro
    El Dobro A Member
    7,102
    3,282
    There's lots of people powering appliances in their homes using power inverters attached to their Prii, so I can't see a problem.
  8. mtlewis
    mtlewis Tinkerer
    47
    Mississippi
    Thank you for responding El Dobro. I think I remember a post where someone used one of the outlets inside the car to power a hand vacuum and fried some expensive component, which makes me more than a little nervous about powering a $75 pump from my $25K car. I would be interested in knowing why it happened and if there is a hazard, is it mentioned in the manual?
  9. PaJa
    PaJa Senior member
    678
    116
    92
    Czech republic
    There is a 15A fuse dedicated just for the central power outlet. It is not connected with any other system. Don't worry, just press Start button to Ready state to omit discharge of 12V accessory battery.
