The 2007 Toyota Yaris
Discussion in 'Other Cars' started by 2Hybrids, Mar 25, 2006.
  1. Tideland Prius
    16,673
    haha. Yeah. I guess people in Japan change cars more often that we do?
  2. Drift Motion
    Drift Motion RMS13
    178
    Pasadena/Riverside, CA
    the honda fit is alot better looking than the yaris
  3. 2Hybrids
    2Hybrids New Member
    565
    Eustis, Florida
    <div class='quotetop'>QUOTE(Drift Motion @ May 9 2006, 07:12 PM) [snapback]252426[/snapback]</div>
    The Fit sure does look like an Xa.... :D
  4. flareak
    flareak Fleet Captain
    1,016
    St Louis, MO
    <div class='quotetop'>QUOTE(NuShrike @ May 8 2006, 01:20 AM) [snapback]251362[/snapback]</div>
    i dont see your point. you're saying that the yaris is just a renamed echo which implies its essentially an echo inside and out with a new name. I'm saying that's not true. If I may use a quote from a website you gave me, "The new Yaris is considerably larger than its predecessor (110 mm longer, 35 mm wider and 20 mm taller, plus a 90 mm boost in wheelbase)"
  5. Drift Motion
    Drift Motion RMS13
    178
    Yaris/Echo/Vitz all the same car, different name in differnet country
  6. Tideland Prius
    16,673
    The old Echo sedan was called the Platz and the old Echo hatchback (only in Canada) was called the Yaris/Vitz.
    The new Yaris sedan is called the Belta and naturally the hatchback has been rid of the Echo nameplate and uses Yaris.
  7. DaveSheremata
    DaveSheremata New Member
    249
    Arlington, Virginia
    Two weeks ago I was in Toronto visiting family - and my mom had her new Yaris sedan. Apparently hers was the sixth one in canada, if you count from the front of the boat.
    I was really impressed with the car - quite peppy and surprisingly smooth for its size. Something about the steering and suspension really reminded me of the Prius, but the brakes were the mushiest I've felt on a small japanese car...
    All in all, very nice.
    Dave
  8. Tideland Prius
    16,673
    really? you should try our 02 Camry's brakes :(. Nothing happens until you're half way through the brake pedal range.
  9. mikepaul
    mikepaul Senior Member
    1,763
    Columbia, SC
    I saw a Scion xA 4-door-hatchback in a parking lot last night. Since my mom is now focused on a Honda Fit to get the 4DH, I told her to at least do a few Internet searches to see if the xA is something she'd like to test-drive.
    She's getting all happy about lower gas prices, but we agreed it probably won't last...
