The $800 hole
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by whicks3, Apr 25, 2012.
  1. whicks3
    whicks3 Junior Member
    23
    Robbinsville,NC
    My daughter's 2011 Gen III had the check engine light come on,and no fiddling with the gas cap helped. The dealer ran a smoke test, and it revealed a small rock nick in the evap line coming off the top off the gas tank. This line only comes with the tank, at $500. Toyota thought to protect the fill hose to the tank,but didn't seem too worried about any of the hoses associated with the evaporative emissions system. With labor,the bill was about $800. No warranty of course. I know a little dab of silicone would have fixed it,but the dealer said that couldn't fix it that way. Her insurance should cover this under a comp claim,still waiting to hear back. Anyway,I just bought a length of 3/4" pipe insulation,and wrapped all of this tubing on my 2012. Of course we will do her car next,and then I'll do my dad's 2010. Remember Murphy's Law,this is a 20 minute fix,don't wait !!! BTW,just in case you were wondering, the tank is coated inside.
    3 people like this.
  2. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,338
    Wilmington, NC
    What a bummer !!
    I think I can understand why the dealer could not repair this hole being that it is part of the evaporative emission systems. I would have told the dealer that I would repair it myself and then patched it when I got home.
    Thanks for the heads-up !!
  3. szgabor
    szgabor Active Member
    993
    175
    Oceanside NY
    http://priuschat.com/forums/gen-iii...ubleshooting/107559-pinhole-in-fuel-tank.html
    check out this thread for alternative solutions ... pay attention to the self tapping screw and duct-tape :)
    :):D:rockon:
  4. whicks3
    23
    Robbinsville,NC
    That's exactly what I told my daughter i would have done. They could have made up something to get paid for the trouble shooting,we did it all the time back when i worked at a Ford dealership. We are saving the old tank of course, remember the "pin hole" post of a few days ago.With 3 Prii in the family, we may need it!!
  5. GSW
    GSW PRIUS POWER
    537
    74
    Jacksonville
    Whicks, is that a picture of the hose wrapped with your 3/4 pipe insulation or is that what the stock hose looks like, (before its wrapped). The first picture looks like your possibly holding the damaged end (damage about 3 ribs down from the top). Thanks!
  6. whicks3
    23
    Robbinsville,NC
    The wrapped pipe in the photo is the fuel fill tube. The smaller flexible tube is the damaged one. there are quite a few tubes in this system once you get under the car. I wrapped them all while I was under there. Since this is a sealed system, a hole in any one of them should cause the check engine light to come on. My next project is to design a skid plate for the gas tank. Plastics are a great weight saver, good at fending off sharp objects,not so much!!!
  7. spiff72
    spiff72 Member
    184
    37
    West Michigan
    OK -
    I am curious about the photos...
    What is the large hole on the top of the tank for? It looks like it is about 4-5" in diameter?
  8. adamace1
    adamace1 Senior Member
    1,403
    191
    Charlotte, NC
    I'm going with fuel pump.
  9. Former Member 68813
    3,524
    981
    US
    Please keep us updated.
    BTW, I'm curious, what is the blue lining inside the tank made of?
  10. fotomoto
    fotomoto Senior Member
    5,597
    3,771
    So. Texas
    Smurf poo.
  11. theprius
    theprius Junior Member
    34
    NY
    hahaahaaa! the real reason the prius is expensive
  12. car compulsive
    car compulsive Active Member
    741
    274
    Michigan
    Good to know. I drive a lot of gravel roads.
  13. whicks3
    23
    Robbinsville,NC
    That is indeed where the fuel pump assembly attaches. There is a locking ring and seal of course. Quite a large hole compared to some others I've seen.
  14. Judgeless
    Judgeless Senior Member
    1,821
    255
    Cleveland, OH
    When I read your post the first thing I thought of was duct tape. I noticed the link that recommended duct tape. That would have fixed it for a lot less.
  15. whicks3
    23
    Robbinsville,NC
    I haven't been able to find out what the liner is made of,of course it's a given that it's flexible enough not to pop off,and let's hope it lasts forever.As a motorcyclist, I'm all too familiar with tank coatings that failed ,let's all hope Toyota got this one right!!!
  16. csolsen
    csolsen New Member
    CA
    Whicks3,
    Can you post a picture/description of where to find this hose underneath the car? Just purchased at 2012 Prius.
    Chris
  17. schorert
    schorert Member
    127
    51
    mass
    "rescue tape" would have sealed permanently, more fuel resistant than duct tape....
  18. schorert
    schorert Member
    127
    51
    mass
    Saab had this great idea to route the fuel filler pipe through the wheel well. So if you cut a tire or picked up some road debris you could split that tube. My wife absolutely shredded a tire and tore the pipe all to hell. So after replacing a wheel and tire, I got a thrilling gush of gasoline at the next fill up!
    Junkyard reduced my total repair bill to $250(incl wheel)...Saab wanted $425 for the filler tube, $80 for the rubber bushing (tubing) to attach to the tank, $500 for the wheel.
    Hope the OP kept the tank, likely has some value on ebay!
